I would like to receive datas from my four espeasys on two different fhem servers. The servers have the addresses 192.168.178.65: 8383 and 192.168.178.134: 8384. If I create fhem twice in espeasys with the different addresses, only one works. Am I doing something wrong here or is it not possible?
Greeting Franzel
Two fhem servers to recive datas
Re: Two fhem servers to recive datas
I assume you have selected the right controller in the tasks from which you need to send data to the controller?
Also how many messages do you send at once, maybe the queue is already full?
Hihi,
yes I have the right Controller but I forgot to mark both Controllers in the devices.
I have solved this problem but I think there ist a new problem with the timing. The fhem-server recived not all values.
If one fhem-server deleted in the espeasys devices the problem ist solved.
Franzel
Franzel
Like I said, how many messages will be sent in a burst?
Maybe you're running into "full queue" for the controller?
