Hello everybody!
I have Wemos D1 with latest test build connected to rotary encoder. I am controlling my receiver volume trough OpenHab mqtt binding. It is working well.
I have two questions:
1. Is it possible to set Espeasy to publish encoder status in real time(fast)?
2. Can I set Espeasy not to publish initial 0 state of encoder on boot, and set it to receive volume topic(in case of IR remote)?
Lets say that after boot, Wemos subscribe to a volume topic, then receive volume status from broker(retained flag), then update the rotary value(from 0 to a new value).
Real time rotary encoder mqtt publish!
Re: Real time rotary encoder mqtt publish!
Yes you can do both using rules. Please study the wiki and get back here if you need further assistance.
OK!
I am not very good at programing. let me start with, do not publish initial state 0 with mqtt...
On System#Boot
if volume#set=0
"do not publish 0"/dont know what to put here
On System#Boot
if volume#set=0
how did you solve this problem?
I haven't been able to set the initial value of a rotary encoder.
I think you should store the value using a dummy device and only let the rotary encoder do the addition / subtraction from that value.
Dummy device may not be a solution, if he wants to allow set volume to 0, but later...
To not set 0 value, it's easier to not send the device value automatically (uncheck "Send to controller" at device edit) and create a rule to publish (but with condition):
However it will not solve much, because when you rotate, then the volume will send value from 1, even the volume on the other side is higher.
You have to receive value from the topic, not just send. To do this, you need MQTT Import device. Name it to "import" for example, set topic and value to "volume", then rewrite the rules:
You will need modify the topic on the other side from volume/set -> import/volume.
on volume#set>0 do
Publish %sysname%/volume/set,[volume#set]
on import#volume do
// assuming the first device/task is the rotary encoder
TaskValueSet 1,1,[import#volume]
emdon
on volume#set do
Publish %sysname%/import/volume,[volume#set]
// assuming the second device/task is the MQTT import. This update may not be necessary, since the value will "come back" via mqtt anyway.
TaskValueSet 2,1,[volume#set]
Hello. Thanks to the encwrite function and everyone who contributed to this, I managed to program it. Happy New Year 2024 to everyone.
on mqtt#volume do
encwrite,[mqtt#volume]
on volume#value do
Publish %sysname%/volume,[volume#value]
TaskValueSet 4,1,[volume#value]
Users browsing this forum: Ahrefs [Bot] and 34 guests
