The Falmec hood is listed as supported device for R 48, but it seems not to work. Any suggestions.
Falmec Support
Re: Falmec Support
http://www.rflink.nl/blog2/development
Make a debug log and mail it..
Re: Falmec Support
20;4F;DEBUG;Pulses=34;Pulses(uSec)=300,270,600,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,270,600,600,240,600,240,6990;
20;50;DEBUG;Pulses=34;Pulses(uSec)=270,270,600,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,270,570,600,240,600,240,6990;
20;51;DEBUG;Pulses=34;Pulses(uSec)=300,270,600,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,270,600,600,240,600,240,6990;
20;52;DEBUG;Pulses=34;Pulses(uSec)=330,240,600,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,240,600,600,240,600,240,6990;
20;53;DEBUG;Pulses=34;Pulses(uSec)=330,240,600,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,240,600,600,240,600,240,6990;
20;54;DEBUG;Pulses=34;Pulses(uSec)=330,270,600,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,240,600,600,240,600,240,6990;
20;55;DEBUG;Pulses=34;Pulses(uSec)=330,270,600,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,600,240,270,600,600,240,600,240,6990;
That was pressing the 'down' on the remote
Re: Falmec Support
Same problem. Some commands work and some non. Sometimes it does not work at all. And it somehow related to distance between rflink and device to control. When I am in a kitchen room then it does not work at all. When I went to living room or upstairs then it works some times and usually not.
I am using:
- Arduino MEGA
- RFLink 433.92 Gateway KIT
- Antenne SMA voor 433MHz
- VER=1.1;REV=48;BUILD=04;
Here it is a log of using remote control:
light on
20;E9;DEBUG;Pulses=34;Pulses(uSec)=240,210,480,480,180,480,180,480,180,480,180,480,180,480,180,480,180,480,180,210,450,480,180,480,180,480,180,210,480,480,180,510,180,6990;
20;EA;FALMEC;ID=7900;SWITCH=01;CMD=ON;
light off
20;EE;DEBUG;Pulses=34;Pulses(uSec)=330,210,480,480,180,480,180,480,180,510,180,510,180,480,180,480,180,480,180,480,180,480,180,510,180,480,180,210,480,480,180,480,180,6990;
20;EF;FALMEC;ID=7900;SWITCH=01;CMD=OFF;
fun speed 1
20;0F;DEBUG;Pulses=34;Pulses(uSec)=240,210,450,510,180,480,180,480,180,480,180,480,180,510,180,510,180,210,480,480,180,480,180,480,180,510,180,210,450,510,180,480,180,6990;
20;10;FALMEC;ID=7901;SWITCH=01;CMD=OFF;
fun speed 2
20;20;DEBUG;Pulses=34;Pulses(uSec)=240,210,450,480,180,510,180,480,180,480,180,480,180,480,180,210,480,480,180,480,180,480,180,480,180,480,180,210,450,480,180,480,180,6990;
20;21;FALMEC;ID=7902;SWITCH=01;CMD=OFF;
fun speed 3
20;23;DEBUG;Pulses=34;Pulses(uSec)=180,210,480,510,180,510,180,480,180,480,180,480,180,480,180,210,480,210,450,510,180,480,180,480,180,480,180,210,450,480,180,510,180,6990;
20;24;FALMEC;ID=7903;SWITCH=01;CMD=OFF;
fun speed 4
20;3F;DEBUG;Pulses=34;Pulses(uSec)=240,210,450,480,180,510,180,510,180,510,180,480,180,210,480,480,180,510,180,510,180,510,180,480,180,480,180,210,480,480,180,480,180,6990;
20;40;DEBUG;Pulses=34;Pulses(uSec)=240,210,480,480,180,480,180,480,180,480,180,510,180,210,450,510,180,480,180,480,180,480,180,510,180,510,180,210,480,480,180,480,180,6990;
back to switch fun off
fun speed 3
20;52;DEBUG;Pulses=34;Pulses(uSec)=330,210,450,510,180,480,180,480,180,480,180,510,180,510,180,210,480,210,480,480,180,480,180,480,180,510,180,210,450,510,180,480,180,6990;
20;53;FALMEC;ID=7903;SWITCH=01;CMD=OFF;
fun speed 2
20;77;DEBUG;Pulses=34;Pulses(uSec)=330,210,480,480,180,480,180,480,180,510,180,510,180,510,180,210,480,480,180,480,180,480,180,510,180,480,180,210,480,480,180,480,180,6990;
20;78;FALMEC;ID=7902;SWITCH=01;CMD=OFF;
fun speed 1
20;8B;DEBUG;Pulses=34;Pulses(uSec)=150,210,450,510,180,510,180,510,180,480,180,480,180,480,180,510,180,210,480,480,180,480,180,510,180,480,180,210,450,510,180,510,180,6990;
20;8C;FALMEC;ID=7901;SWITCH=01;CMD=OFF;
fun off
20;95;DEBUG;Pulses=34;Pulses(uSec)=150,210,480,480,180,480,180,510,180,510,180,510,180,480,180,480,180,480,180,480,180,510,180,510,180,480,180,210,480,480,180,480,180,6990;
20;96;FALMEC;ID=7900;SWITCH=01;CMD=OFF;
And there is a command 'fun speed 4' it have not decoded.
If you need more information just let me now.
I am using:
- Arduino MEGA
light on
light off
fun speed 1
fun speed 2
fun speed 3
fun speed 4
fun speed 3
fun speed 2
fun speed 1
fun off
Re: Falmec Support
Did you ever get this working OK, @chinaryov?
chinaryov wrote: ↑09 Feb 2021, 13:12 Same problem. Some commands work and some non. Sometimes it does not work at all. And it somehow related to distance between rflink and device to control. When I am in a kitchen room then it does not work at all. When I went to living room or upstairs then it works some times and usually not.
I am using:
- Arduino MEGA
light on
light off
fun speed 1
fun speed 2
fun speed 3
fun speed 4
fun speed 3
fun speed 2
fun speed 1
fun off
Re: Falmec Support
Please provide additional debug data for non supported buttons..
Users browsing this forum: joereecedj_94 and 1 guest
