Lost remote
mwmaster
Lost remote
#1 Post by mwmaster » 23 Nov 2023, 19:51
I lost the remote of my Brennenstuhl RCS 2044 switch. Can any one help me to get them working again. :oops:
bidrohini
Re: Lost remote
#2 Post by bidrohini » 20 Dec 2023, 09:22
I am not sure if this is the right place to post this question. This forum is about Espeasy. Is Brennenstuhl RCS 2044 switch supported by ESPeasy. Hope somebody will come forward and clarify.
Re: Lost remote
#3 Post by TD-er » 20 Dec 2023, 09:48
Well this subforum is about the RF-link, so I think it might be ontopic?
mwmaster
Re: Lost remote
#4 Post by mwmaster » 20 Dec 2023, 11:09
it's about RF-link sorry,
I ony need the Packet structure for the Brennenstuhl RCS 2044 switch for 3 switches
Data:
10;Protocol Name;device address,button number;action;
bidrohini
Re: Lost remote
#5 Post by bidrohini » 20 Dec 2023, 13:17
Have you checked The Brennenstuhl RCS 2044 switch's manufacturer's documentation? I assume it uses a uses a proprietary protocol.
Stuntteam
Site Beheer
Re: Lost remote
#6 Post by Stuntteam » 20 Dec 2023, 18:45
It largely depends on the type of Brennenstuhl device.
There are the models that follow the ARC protocol which have dip switches or wheels to set the device address.
There are also the models that use auto-learn with encrypted communication.
Both should be supported by RFLink.
However, the packet structure depends on the type.
If it is one of the auto-learn models you probably need to use:
10;EURODOMEST;03696b;0;ON;
10;EURODOMEST;03696b;1;ON;
10;EURODOMEST;03696b;2;ON;
and learn these addresses to the switches following the manufactureres rules
mwmaster
Re: Lost remote
#7 Post by mwmaster » 21 Dec 2023, 15:47
@bidrohini, I have read the manual, but there is nothing mentioned about the protocol used.
@Stuntteam, thank you for your message!!
I am using the Brennenstuhl type with dip switches, presumably using the ARC protocol.
Do you also have a packet structure example for this? :D
