Reason why some devices show simple web interface?
what is the reason that the web interface of some of my ESP 8266 devices look like the picture below and not like the normal design?
I know this simple web interface from connecting the first time via access point, afte connecting with my wifi the normal design is shown but now I have the simple design for running and connected devices too ?
Is the design a reason of browser settings or a general problem?
Thomas
Thomas
- simple design.JPG (74.62 KiB) Viewed 5917 times
Re: Reason why some devices show simple web interface?
It seems like when a build was made without pygit2 installed as Python library, you do end up with a CDN url without a Git tag in the URL.
And it looks like jsdelivr is suddenly no longer accepting those URLs.
I made a quick fix, but you probably need to make a new build for it to work again (assuming you made your own build)
https://github.com/letscontrolit/ESPEasy/pull/4874
thank you for the answers! I am new so I don't understand everything.
What does that mean for me? What should I change?
"It seems like when a build was made without pygit2 installed as Python library, you do end up with a CDN url without a Git tag in the URL.
And it looks like jsdelivr is suddenly no longer accepting those URLs."
I have another device running with version ESP_Easy_mega_20230507_normal_ESP8266_4M1M May 7 2023 and there everything is ok.
A new build means that I have to flash the ESPs again with a new ESP_Easy version?
This would be bad because the ESPs are hard to reach in their locations. I use ESP-01
That's correct. ESP01 and other 1MB Flash units are really hard to keep supported, as we are constantly running out of the .bin size, so 4MB units like the NodeMCU and Wemos D1 mini clones are much easier to use. They also have more GPIO pins available.
For new installations it's better to base your plans on ESP32 devices, for replacing the small ESP01 there are close 'competitors' in size like the ESP32-C3 mini devices (f.e. these, or these). These units usually have 4MB flash, and can be updated via OTA (Over The Air = via the browser).
Edit: There is even an ESP32-C3 that's pin compatible with the ESP01 -> https://aliexpress.com/item/1005003538055090.html
When you need to open up those devices with an ESP01, please take the time to solder on a new 4M flash chip as it makes life so much easier.
ok... bad...
I work now with s2 minis
maybe I change my ESP01 with them
For my understanding:
What happened that it worked before with the normal web interface and now it doesn't wortk anymore?
As I mentioned if I connect the first time via AP I always have the simple look and after connecting with my wifi the normal web interface appears?
It is really necessary to flash it again?
Because my sensor reading is still fine and this is all I need.
We do rely on some external service to host static files like the CSS and JavaScript files.
And all of a sudden those links are no longer working.
N.B. there is also some LillyGo module with an ESP32-C3 with the exact same form factor as the old ESP01.
See: https://templates.blakadder.com/T-01C3.html
No...
Use "file upload" under "/tools"
and upload the files of the attachment one by one..
Note: you need around 9kb of free space for that.. but that is usually the case
- espeasy_files.zip
- (7.53 KiB) Downloaded 130 times
you mean
"File browser Show files on internal flash file system"
and then upload the *.js files?
Thank you for the help!
On an 1M flash unit this 9k can be challenging...
By the way, I think you can also gzip them and then upload them as .js.gz
This won´t work: "update_sensor_values_device_page.js.gz"
It is to lengthy
It is to lengthy
is it right what I wrote ?
Ah yes, have to check the source code as I have made a replacement name for it when serving embedded JS...
Rename it to upd_values_device_page.js
or upd_values_device_page.js.gz if you GZipped it..
ok I uploaded all files but it doesn't work
should I delete the "update_sensor_values_device_page.js" file ?
and upload the renamed file again ?
I uploaded "upd_values_device_page.js" but it doesn't work
- js.JPG (44.36 KiB) Viewed 5813 times
yes it worked
Thank you!
Thank you!
Keep in mind that whenever you have issues saving settings, you may want to remove one or more files as SPIFFS filesystem needs some free space to work on.
Users browsing this forum: Ahrefs [Bot] and 2 guests
