Another bathroom ventilation project
Bluesea
#1 Post by Bluesea » 15 Oct 2023, 12:10
I have a two speed bathroom fan. I want to turn them on depending on the humidity. And it should block from turning on automatically during the night.
I put everything together, And it runs so far, but he is running always on level 1. I think something on my script is wrong.
Does anyone with experience see the fault?
on [TempHum#Humidity]<65 do //if humidity under lowerlevel then van off
gpio,14,1
gpio,12,1
on [TempHum#Humidity]>65 and [TempHum#Humidity]<75 do //if humidity between lower and uper level then van level1
if [VirtualSwitch1#Dummy1]=0 //check if night block
gpio,14,0
gpio,12,1
on [TempHum#Humidity]>75 do //if humidity over uperlevel then van level2
gpio,14,0
gpio,12,0
Re: Another bathroom ventilation project
#2 Post by Ath » 15 Oct 2023, 12:26
Bluesea wrote: 15 Oct 2023, 12:10 Hello
There are a few syntax errors in your code: (Check Rules syntax here: https://espeasy.readthedocs.io/en/lates ... Rules.html)
on TempHum#Humidity do
  if %eventvalue1%<65 or [VirtualSwitch1#Dummy1]=1 //if humidity under lower level or night-block then fan off
    gpio,14,1
    gpio,12,1
  if %eventvalue1%>65 and %eventvalue1%<75 //if humidity between lower and upper level then fan level1
      gpio,14,0
      gpio,12,1
  if %eventvalue1%>75 //if humidity over upper level then fan level2
      gpio,14,0
      gpio,12,0
(Kept the code structure close to your original)
(Air code ;))
#3 Post by TD-er » 15 Oct 2023, 12:37
Yep, the main thing you should realize is that in the on...do part you should not use []
When parsing the rules, everything wrapped in [] is being converted into a numerical.
Thus the on...do part will probably not match if you use [] in that line.
Also you can't use "and" or other logic operators in the on...do line.
Bluesea
#4 Post by Bluesea » 15 Oct 2023, 12:52
Wow, thank you very much! Now it does what I want. I'm still learning this rules.
Users browsing this forum: No registered users and 31 guests
