Moisture Sensor from BeFlE
Dear Community,
I have bought an Moisture Sensor called SoMoSe from BeFlE and am trying to get it working.
Sadly a couldn't find a device to get the Sensor working.
Does anyone know how to get the sensor working?
Is there a way to get an i2c device running without the separate device?
I`m not a developer and my knowledge is not good enough to understand what the developer ment.
https://github.com/BeFlE/SoMoSe
Thank´s for your help
Re: Moisture Sensor from BeFlE
ESPEasy currently supports this moisture sensor.
The plugin for this sensor is available in all Collection builds and the Climate build.
There is no support (yet) in the plugin for the model you have selected (have a link where to buy that?), but it's possible to add that. Your sensor doesn't support the "Light" measurement, that is available in the miceuz sensor I linked, so that would read 0 in all cases.
Thank`s a lot!
I have created PR #4582 that adds support for the BelFlE Soil moisture sensor. Can you please test using this Actions build (once it's finished, you will need one of the Collection builds, or a MAX build when working with an ESP32 with 16MB Flash), and report your findings here?
NB: I ordered such sensor myself, so have already done some quick tests here.
Edit: Updated to newer Actions build
WoW, really quick!
Seams to work, i'll gonna test in soil for the next week!
And check how it is working with a second sensor.
Thanks a lot!
Thanks a lot!
Everything fine, seams to work great!
Shall i test anything else?
Thanks for reporting your results.
I've updated to latest available mega update, but that shouldn't change the working of this plugin, though you are welcome to re-test using the latest build from this Actions run
The PR has been merged, and included in the latest release. Documentation is also updated.
Which release binary I have to flash to get the BeFlE moisture sensor on a Wemos D1 mini?
If I flash the current one ESP_Easy_mega_20230822_normal_ESP8266_4M1M.bin I can not see any device Environment - Soil moisture sensor.
As mentioned in the link posted by Ton: https://espeasy.readthedocs.io/en/lates ... #p047-page
It should be in all "Collection" builds and also the "Climate" build.
So the build ESP_Easy_mega_20230822_collection_C_ESP8266_4M1M.bin would be the right one?
It's a little bit difficult if you are new to EspEasy...
Yep, any "collection" would be OK.
Just have a look at any other plugin you may also need to see if "collection_C" would be the best choice for you.
See: https://espeasy.readthedocs.io/en/lates ... al-plugins
I how flashed the Collection_C Firmware and configured BeFIE Sensor AS device. SDA: GPIO-4 (D2) and SCL: GPIO-5 (D1) but I get no readings. Voltage of the sensor ist connected correctly to 5V of the Wemos D1 mini.
What ist going wrong? How can I debug it?
Can you see it as an I2C device in the I2C scan? (tools page)
Thank you. I2C scan Said "No devices". I reattached the cable and now it's measuring without resoldering. Values are a bit off, i.e. temperature about +6°C. Moisture weg is around 140 which should be 100 as maximum.
Is it possible to calibrate the Sensor via ESP Easy? I have a few "Trübner SMT50" soil moisture sensors which are really good (precise out of the box) but expensive, too.
I'd suggest to connect the sensor to 3.3V, as the GPIO pins of the ESP are not really specified for 5V, though there are some ppl using that all the time, it's still not advised.
The only calibration available in this plugin is the Formula field, next to the Values names. For Temperature it's usually enough to subtract the desired offset, but I don't know how linear the Moisture reading is, so maybe you can get calibration values from another, more accurate, device when measuring close to this sensor? You should then be able to derive a formula from that data.sptotal wrote: ↑30 Sep 2023, 14:20 Values are a bit off, i.e. temperature about +6°C. Moisture weg is around 140 which should be 100 as maximum.
3.3V instead of 5V seems to be the solution. Now I have really consistent readings which seems to be true if nothing changes.
Thank you for the fast good support
Is it possible to use multiple BeFIE moisture sensors with one Wemos D1 mini? Each Sensor gets it's own I2C adress and all of them connected to the same GPIO pins.
Or is only one sensor of one type supported by the firmware?
Multiple sensors can be configured and work at the same time but I'm not (really) sure if they keep their manually set I2C address, as there doesn't seem to be a 'save' operation available.
That would make restarting the unit after power-loss rather cumbersome.
Or you could try using an I2C multiplexer.
Then the multiplexer output determines what sensor is addressed.
I just tried: If you change the I2C address by ESP Easy then this will be a permanent setting for the BeFIE. Running two sensors on one Wemos D1 mini on different addresses the address change will be permanent and survive a reboot (or cut off voltage).
GREAT
GREAT
That's great
I'll try to keep that knowledge in memory, but that may be hard
The I2C address can be chosen freely between 0x01 and 0x7F for this sensor, but when connecting many (> 5) of them you should remove the 10k pull-up resistors from all but 1 board, to avoid overloading the I2C bus with too low pull-up resistance. When connecting other I2C devices you should avoid the address(es) used there. And your I2C scan (Tools page) may look weird, reporting completely different devices than actually connected
And of course you are limited to the number of tasks (Devices) on your ESP (max. 12 tasks on ESP8266, max. 32 tasks on ESP32).
If only we had some way to document specific info about plugins...
There will be a new low power version of the BeFlE Somose sensor released. This sensor needs new logic to work.
Can anybody please tell me how to adjust the code of the P047 module to get the new sensor working?
Here are the changes of the Arduino implementation of the new sensor:
SoMoSe_Arduino.h https://github.com/BeFlE/SoMoSe/compare ... c2eedd3058
SoMoSe_Arduino.cpp https://github.com/BeFlE/SoMoSe/compare ... e18df48646
SoMoSe_Arduino.cpp https://github.com/BeFlE/SoMoSe/compare ... 5b156ac281
We're not using the library from BeFlE, (and looking at that code makes me really unhappy, seeing f.e. the inconsistent method naming and the many spelling errors ).
When will that sensor be available? as it looks best & easiest to me to have it added as a new/extra model to the plugin, and integrate the changes within the current code.
You're welcome to create a PR for it, but I can also pick it up, somewhere in the near future.
We have a developers guide available: https://espeasy.readthedocs.io/en/lates ... ormIO.html
The new sensor will be released end of May. See https://github.com/BeFlE/SoMoSe/issues/ ... 2096156495
I am really on the lowest level of programming concerning hardware in EspEasy. I only know the basiscs of rules to control my ESP
I've created pull request #5049 to add support for the new BeFlE v3.x hardware, based on the updated code in the BeFlE SoMoSe repository
@sptotal I haven't planned to order the new sensor, but I assume you are ordering one. Can you test the code from the PR on the actual hardware? Download binaries from this Github Actions run. (You can only download when logged in with a Github account.)
Users browsing this forum: No registered users and 4 guests
