Set Somfy RTS blind in pairing mode from RFLink
tehtwig
#1 Post by tehtwig » 11 Sep 2023, 20:20
I've accidentally crushed my physical RTS remote. This remote was the main remote of my blind. When doing a long press on the button on the back, the blind was set to a pairing mode, waiting for a new remote (or the RFLink) to be paired.
I already have a working entry for this bling in my RFLink, UP;DOWN;STOP commands are working without any issue.
Now that I don't have this physical remote anymore, is it possible to send this pairing mode request to my blind with the RFLink ?
Stuntteam
Site Beheer
Re: Set Somfy RTS blind in pairing mode from RFLink
#2 Post by Stuntteam » 12 Sep 2023, 08:44
UP, DOWN, STOP, PAIR are available
ON and OFF can also be used as equivalent of UP and DOWN
tehtwig
#3 Post by tehtwig » 13 Sep 2023, 12:41
Thank you for your reply :)
To set the blind in pairing mode, first I have to simulate a long press on the physical PAIR button on the remote (which I don't have anymore). This command only sends a short PAIR signal :
10;RTS;AAAAAA;0001;B;PAIR;
How can I simulate a long press on this PAIR button with RFLink ?
Stuntteam
Site Beheer
#4 Post by Stuntteam » 13 Sep 2023, 16:57
The pair command is the same as pressing the button at the back of the remote.
It is used for registering and deregistering remotes from the motors memory..
tehtwig
#5 Post by tehtwig » 23 Sep 2023, 09:43
Thanks for your reply.
The simple button push can be used to pair/unpair a remote ONCE the blind is listening in pairing mode.
Unfortunately, a simple button push doesn't tell the blind to go to pairing mode. You need to do a long press for that.
I think there's no RFLink solution here, so I've done the electrical reset procedure on my blind to fully erase it's memory and set it in pairing mode for 2 minutes.
Thank you again :)
