Rules If statment String
Sjuul
#1 Post by Sjuul » 30 Aug 2023, 10:05
I'am busy to connect my airco to ESP-Easy receiving data string works great.
The mode of the airco is transferred in a string like "FAN"
Now I try to make in the rules of ESP-Easy an if statement with this string see the code below
If [Airco2#mode] = 'FAN'
 SendToHTTP 192.168.1.100,8080,/json.htm?type=command&param=switchlight&idx=384&switchcmd=Set%20Level&level=10
Endif
This doesn't work,
Has someone any suggestions to send the HTTP command when the "Fan" string is received?
Re: Rules If statment String
#2 Post by Ath » 30 Aug 2023, 10:11
ESPEasy does not support processing string values in rules like that at this time.
How are you receiving those values?
Can they be replaced by numerical values on the sending side? As those can be handled by ESPEasy.
Sjuul
#3 Post by Sjuul » 30 Aug 2023, 11:57
Below the string i recieved.
Airco2#settings=`{'roomTemperature':19.0,'wideVane':'<<','power':'OFF','mode':'FAN','fan':'1','vane':'1','iSee'
As you can see there are some numbers but not for everthing.
#4 Post by TD-er » 30 Aug 2023, 12:09
How do you receive this string?
Via MQTT?
Sjuul
#5 Post by Sjuul » 30 Aug 2023, 13:09
It comes from "HwSerial port 0" Port to GPIO1 and GPIO3
I use this plugin https://espeasy.readthedocs.io/en/lates ... /P093.html
#6 Post by Ath » 30 Aug 2023, 14:46
Well, you can use the substring function (docs) and indexof function (just below the substring function in the docs) to find and extract the value, into another indexof to find some known values, and use that for comparisons, something like this:
(Be prepared that this isn't very efficient, of well designed yet, just dumping my brainfart :lol:)
on airco2#settings=* do // use the asterisk to allow non-numeric 1st argument
  let,1,{indexof:mode:"%eventvalue1%"} // Start position of word: mode
  let,2,{indexof:FAN:{substring:%v1%+8:%v1%+11:%eventvalue1%}} // TODO: Check offsets
  if %v2%>-1
Disclaimer: Air code, untested
Edit: Fix some typos
Sjuul
#7 Post by Sjuul » 30 Aug 2023, 16:08
Thanks Ath,
This gives me an eye opener.
The plugin 0092 can give also sort value [Airco2#mode] returns only FAN
Just after the position you mentioned in the online help I found the function {equals:<string1>:<string2>}
 If {equals:[Airco2#mode]:FAN} = 1
  SendToHTTP 192.168.1.100,8080,/json.htm?type=command&param=switchlight&idx=384&switchcmd=Set%20Level&level=10 //10 = Ventileren in Domoticz
#8 Post by Ath » 30 Aug 2023, 16:51
Ah, yes, that's much easier. Don't have any experience with this plugin :? though I have added that feature to get all values, and wrote the documentation (here). :lol:
