Hi All,
I am in New York and I just receive my RFlink device from https://www.nodo-shop.nl and I assembled it successfully and am here for some guidance.
I use Home Assistant Core on a Synology NAS and it works well. I simply need guidance in getting the RFlink configured.
Hello All
Re: Hello All
Since you received no reply here, I think you can post your question to the home assistant forum.
Re: Hello All
Well, you as misinformed as ever, there is a RFLink section in this forum, where the question should have been directed to, as that's what the real question is about.
Re: Hello All
I see. Thank you Ath.
Dear m_ny, I hope you have solved this issue by this time. If not, you can post your question again in this section: viewforum.php?f=8
Users browsing this forum: Ahrefs [Bot] and 39 guests
