Communication-Serial-Server TX-Enable
cbamav
#1 Post by cbamav » 01 Jun 2023, 22:57
i need to communicate with an RS485 Device from my PC over Ser2Net to an ABB Aurora Inverter. So i pluged a TTL to RS485 board on my ESP32. The problem is the TX-Enable Pin on the RS485 board.
How can i set thies signal from my ESP32. On a old Screenshot from version 20210223 the option TX-Enable is pressent. But on the current version this option is not available. But i need the new version because i have 2 devices and this is possible again with the new version...
Can someone tell me where this option is in the current version or what other options there are for generating the TX-Enable signal?
Thanks very much
TTL_2_RS485_Board
TTL_2_RS485_Board
current version
current version
old version from 20210223
TX Enable.png (98.59 KiB) Viewed 535 times
Re: Communication-Serial-Server TX-Enable
#2 Post by TD-er » 01 Jun 2023, 23:08
With MAX485 chips you typically can connect the DE/RE pins with the TX.
The DE and /RE are eachother's inverse and this way the chip is set to "sending" mode when you try to send a bit.
cbamav
#3 Post by cbamav » 02 Jun 2023, 16:24
i will try it.
my concern is that if I send a 0/low over TX the line will be released on the RS485 when RE/DE go low and some weird signal will be generated.
#4 Post by TD-er » 02 Jun 2023, 19:40
It is really not that uncommon to wire it like this.
Source
cbamav
#5 Post by cbamav » 03 Jun 2023, 20:51
i don`t find my Problem. i started from this pcture:
https://b2600043.smushcdn.com/2600043/w ... p=1&webp=1
my first stap was to remove the RS485 bard and made a wire from RX1 to TX2 and a 2nd from TX1 to RX2. i configured my ESP32, opend 2 terminals an everything was working => ESP-Config is ok
my next step was adding the 2 RS485 boards again and i put the DE/RE Line to the TX Pins. -> No communication
now a put the DE/RE Line on the first RS485 to GND and the 2nd to 3.3 Volt to geht a Communication in one direction, but it was still not working.... I cant find my problem.
but back to the first question. is the Option "TX Enable PIN" no longer available?
i think this is necessary if i sand a 0-bit. The De/RE Line should stay on hight so it is not possible to conntex DE/RE to the TX Pin
