Hello to all forum users.
I have a problem with the ESPEasy mega-20220427 water meter.
I have devices-pulse counter set as in picture. The problem is that when I select "Enabled" and click "Submit", everything works, the counter only counts, but after a few days "Enabled" turns itself off and the counter stops counting. I have the same effect on ESPEasy mega-20230306, and the same on other ESP8266-07 boards.
On the ESPEasy mega-20220427 version, I have an energy meter made and it works without a problem, I copied all the settings to the ESPEasy mega-20220427 water meter and it doesn't work.
Has anyone had this problem, any ideas?
ESPEasy pulse counter
Re: ESPEasy pulse counter
When ESPEasy crashes during boot and thus never is able to complete a boot cycle, a protection mechanism is activated.
After 10 of such crash-boots, ESPeasy starts disabling tasks, one at a time.
Then all tasks, then the same for controllers and disabling rules, etc.
All until it can complete a boot cycle.
What pin is being used for the pulse counter?
Do you immediately act on events sent by the pulse counter task?
N.B. I don't see any picture.
I missed this photo, already posted. How to fix it?
- esp.png (32.8 KiB) Viewed 1138 times
Ah, GPIO-2 is a special pin.
It is a so called "boot strapping pin", meaning the pin needs to be in a specific state during boot or else the ESP will not boot or not boot correctly.
See: https://espeasy.readthedocs.io/en/lates ... on-esp8266
So this is a tricky pin to use when you use it for something you can't control during boot.
Since this pin already had a pull-up resistor, you may also want to test whether you need to add an extra pull-up resistor for your setup when moving it to another pin.
But I have a meter connected to GIPO-4 as in the picture. I have made two ESPEasy plates with the same firmware for counting cold and hot water, so far the heat works fine only with the cold one there is a problem.
Sorry, have been bitten by those absolutely horrible D-naming for the ESP8266....
I didn't look long enough at your screenshot, you're right GPIO-4, D2.... It's not like this happed before to me...
OK, so you're using GPIO-4, that's good
However, this pin is also by default assigned as pin for I2C.
Make sure it isn't set there on the Hardware tab.
I checked, I2C is disabled.
I'm out of ideas!
I'm out of ideas!
How is it wired to the ESP?
Is it possible this pin might receive a lot of noise?
The theory is that it might need to process a lot of interrupts while booting, which may lead to crashes.
A relatively simple work-around might be to set the task disabled and save this setting.
Then in the rules start a timer after boot and then call taskenable,N where N is the task index of your counter.
Users browsing this forum: Google [Bot] and 2 guests
