SN0311 / A0221AU UART Ultrasonic Sensor
Pierrem31
#1 Post by Pierrem31 » 26 Mar 2023, 14:54
Hi all,
As I am a newbie in the ESP world, I don't even know if my project in feasible "As it"
By the past I made a CO2 sensor connected trough MQTT to my HomeAssistant, using the same board and firmware.
https://emariete.com/en/diy-co2-monitor-wifi/
Anyway :
I would like to read my sensor A0221AU using EspEasy on my ESP80 board (ref below)
So, my first question is : is it possible to read UART using this board and this firmware ?
I didn't find the answer in this forum, but I found some tests, and I tried to add a "Generic Puls Counter" : there is "Something" as a result when my sensor is connected : I keep hope !
I you have any information to help me, it would be great,
Thank you
Pierre
from
https://wiki.dfrobot.com/_A02YYUW_Water ... KU_SEN0311 :
UART Output
Output Communication
When "RX" floats or input High level, the module outputs processed value, the data is more steady, response time: 100-300ms; when input Low level, the module outputs real-time value, response time: 100ms.
UART data bit stop bit parity band rate
TTL level 8 1 none 9600bps
UART Output Form
Frame Data Description Byte
Header 0xFF 1 byte
DATA_H Distance Data High 8-bits 1 byte
DATA_L Distance Data Low 8-bits 1 byte
SUM Checksum 1 byte
UART Output
Header DATA_H DATA_L SUM
0xFF 0x07 0xA1 0xA7
Note: checksum only reserves the low 8-bits of the accumulated value.
SUM=(Header+Data_H+Data_L)&0x00FF
=(0XFF + 0X07 + 0XA1)&0x00FF
=0XA7;
Distance= Data_H*256+ Data_L=0X07A1;
Equal to 1953 when converted into decimal;
Represent the current measured distance is 1953mm.
https://fr.aliexpress.com/item/40005500 ... 90182%21sh
https://www.aliexpress.com/item/1005003 ... 30906%21sh
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 97 guests
