mega-20221224 and 4 digit LED display
I use 4 Digit LED Display with a very old version of FW.
I improved the source of this display myself because when showing the temperature, the display showed negative values as e.g. "-:2" instead of "-0:2".
So - at least for me - in a hardly legible way.
I did not analyze the mega-20221224 source, hence I have a question.
In this version and for this display negative values in the range -1C to 0C are presented as e.g. "-:2" or as "-0:2" ?
Re: mega-20221224 and 4 digit LED display
I assume you are pointing at P073, the 7-segment display.
Most likely those issues are now fixed, as quite some work has been done on that plugin in the last 2 years. Best route would be to try...
If it (still) doesn't work as expected, we can probably correct that.
Yep, 7 segment LED display. Dont have at this moment test one and I dont want to test on already working unit.
Need to buy one.
Need to buy one.
OK, tested. Leading zero is shown when temperature is -1C to 1C
However, there is another problem.
On the 4-digit display, the hour in the range 0-9 is displayed with a leading zero.
Can this be removed somehow?
I display the time using the command:
The clock is displayed with a command because the push-on button installed switches the display to different physical values.
7dst,%syshour%,%sysmin%
- Andrew Mamohin
Strange, because there are two variables (with and without it: %syshour% // %syshour_0%), but you use it without zero.mackowiakp wrote: ↑25 Mar 2023, 15:20 On the 4-digit display, the hour in the range 0-9 is displayed with a leading zero.
Andy.
Yep, the same with %sysday% / %sysday_0% and %sysmonth% / %sysmonth_0%.
I think its a driver problem (P073_7DGT.ino).
AFAICS, the hour part of the time is always displayed with a leading 0 when < 10, so changing that would be a feature request, as currently there is no way to configure that.mackowiakp wrote: ↑25 Mar 2023, 15:20 However, there is another problem.
That includes the 7dst command, you might want to consider using the 7dtext command like:
let,24,%syshour% // use intermediate variable to allow formatting
7dtext,"[int#24#d2]%sysmin_0%"
Ok I see. Only I was a little surprised that in the version from before (probably) 5 years "0" was not displayed and now it is.
It is true that then there was a problem with "0" when displaying the temperature in the range -1C - 1C.
But I was able to change the source.
The display of time, using 7dst, and temperature, using 7dt, use separate/independent formatting routines. See my edited response above for a solution (without changing the ESPEasy sources)mackowiakp wrote: ↑27 Mar 2023, 22:08 Ok I see. Only I was a little surprised that in the version from before (probably) 5 years "0" was not displayed and now it is.
Maybe a bit different but I also tried to display the time (date) as text.
But then no colon is displayed.
Enabling the Option "Text show periods as dots" should take care of that when you insert a period between the 2 parts of the date, and using the 7dtext command. (It should enable the colon on displays that have them, as those usually don't have a dot on each segment)
Hmmm... "Text show periods as dots" - there is no such option....
[maciek@Piotr src]$ grep "Text show periods as dots" * 2>/dev/null
[maciek@Piotr src]$
Oh sorry! No "dots" but "dot"...
THX ! Problem solved !
I've added optional suppressing any leading zero on Hour/Day as a feature in the plugin via PR #4577, get a test-build from this Actions run. NB: Not available in the Collection builds! (to save .bin size).
Fine. Will test...
Users browsing this forum: Google [Bot] and 32 guests
