Sluggish ESPEasy Web UI within 24 hrs after booting – Memory leak?
Wookbert
#1 Post by Wookbert » 08 Mar 2023, 11:46
Setup
  • Wemos D1 mini
  • BMP280 (Temperature and Air Presssure sensor)
  • BH1750 (Ambient Light sensor on GY302 board)
  • Build: ESP_Easy_mega_20230306_normal_ESP8266_4M1M Mar 6 2023
  • Generic HTTP post controller report active
  • Advanced option: Check I2C devices when enabled (ACTIVE)
  • Advanced option: CPU Eco mode (ACTIVE)
Problem
Within 24 hrs. after booting the Web UI becomes extremely sluggish, Tools/Advanced doesn’t seem to load at all. Rebooting immediately resolves the issues, Web UI becomes snappy again ... for a few hours.
What am I doing wrong, what can be done to permanently fix this?
Bildschirm­foto 2023-03-08 um 11.37.47.png (272.14 KiB) Viewed 799 times
Re: Sluggish ESPEasy Web UI within 24 hrs after booting – Memory leak?
#2 Post by TD-er » 08 Mar 2023, 12:30
When you suspect a memory leak, it is best to also log the free memory by adding a sysinfo task to record the memory usage.
Also turning off "ECO mode" may be a first start to see if that makes a difference.
And while you're at it, enable the option right above it: "Periodical send Gratuitous ARP"
