Rules - Dummy device not triggered
zigberg
#1 Post by zigberg » 05 Mar 2023, 19:08
My dummy device not triggered when I change a value. It is ok or I miss something?
I made Dummy device #6 with name asicRelay and 1 value AsicState
Via timer I change value and expect after that must fire up trigger asicRelay# AsicState but it not happens
This simplified code
On System#Boot do
 loopTimerSet,1,3 //start timer
 Let,1,0 //just counter
On Rules#Timer=1 do
 Let,1,%v1%+1
 taskvalueset 6,1,%v1% //here I change value of dummy device and expect "asicRelay#AsicState" must execute
On asicRelay#AsicState do //this my dummy device
 ...this not execute :(
Please help
Re: Rules - Dummy device not triggered
#2 Post by Ath » 05 Mar 2023, 19:34
The TaskValueSet command doesn't generate events for the Dummy Device, these can be generated every Interval seconds (default = 0 -> No events generated), or by using the TaskValueSetAndRun command, that will set the value and also 'run' the task, generating the events you expect.
zigberg
#3 Post by zigberg » 05 Mar 2023, 20:38
Oh, I see. Thank you very much, you save me tons of time.
