I have a Phenix remote crontrol with 4 power plugs.
The remote is configured like this (DIPs): 1: UP, 2: down, 3: down, 4: down, 5: down
To switch ON my B power plug, I push the buton B ON, in rflink I get : 20;54;AB400D;ID=42;SWITCH=02;CMD=ON;
Now I want to do the same but from Rflink. I send this: 10;AB400D;000042;02;ON;
I receive "20;56;OK;" but my power plug doesn't switch ON.
Which command do I have to send ? I can't understand how is it working.
Thanks a lot
Phenix remote control, how to use ?
Re: Phenix remote control, how to use ?
Are you sure that the command 10;AB400D;000042;02;ON is correct? Is the any manual or tutorial that you're following?
I'm not 100% sure of the command.
I've read the documentation and according to me it's correct but maybe not
I have no idea what the dipswitches are reflecting.
I have tested with commands like:
10;AB400D;00004d;1;OFF;
10;AB400D;00004d;1;ON;
Where 4D is the hexadecimal value of a ascii character which is supposedly set with your dip switches
So I guess:
10;AB400D;000042;2;ON;
10;AB400D;000042;2;OFF;
So I guess:
It's not working
It is a Phenix (not a real AB400), Is it the YC-4000 model (using HX2262 chipset) ?
Alternatively you could try the rffind option.. (https://www.rflink.nl/faq.php#RFFind)
Yes, it's written YC-4000B on the back of the remote control
