I recently buy a RFLink 433.42 for control my portal motor, a Somfy Freevia.
I think that I success to pair because of the led turn on on the motor when I did it.
But when I tried to send the command STOP for open or close the portal, nothing happen.
I saw when I use my remote (only one click) :
20;20;Debug;RTS P1;a4f904e652f44cc40019;
20;21;RTS;ID=252f44c;SWITCH=01;CMD=STOP;
20;22;Debug;RTS P2;a4f904e652f44cc80026;
20;23;RTS;ID=252f44c;SWITCH=01;CMD=STOP;
20;24;Debug;RTS P3;a4f904e652f44c880022;
20;25;RTS;ID=252f44c;SWITCH=01;CMD=STOP;
The command seems to be send 3 times with P1 / P2 / P3, is it normal ?
Can this is the issue ?
Hope that someone can help me,
SOmfy RTS
Re: SOmfy RTS
No, thats normal..
Re: SOmfy RTS
So I retry today and when I pair I saw the Led turn on and off.
Then when I send the Stop command the led blink but nothing move, have you any idea ?
Re: SOmfy RTS
I finally succeeded, even the remote send only the command STOP.
With Rflink Loader it's the commands UP and DOWN that control the portal
Thank you for your time
Users browsing this forum: Ahrefs [Bot] and 3 guests
