NeoPixel (WS2812b) stability
M*I*B
#1 Post by M*I*B » 11 Jan 2023, 12:01
Hello there,
while I'm waiting for some hardware to go future with my other projects I play around with a 2812 RGB-stripe. For now any because my wife like that also (great! Some thing to upper the WAF) I have just create a simple clock with 12 LED's. I use a S07S for that with the last 1M VCC-build. The stripe have it's own power source (5V 5A PSU), the ESP is connected to a buffered powerpack.
What I have learned is that the stripes / the 2812 and/or the NeoPixel- plugin aren't stable. Sometimes one or more unaddressed LED comes up with a random color, sometimes the whole stripe show me the "finger" and all or most of all LED show any random color.
The rule is very simple:
On Clock#Time=all,**:** Do
	TaskValueSet,tick,h,%syshour%
	TaskValueSet,tick,m,%sysmin%
	If [tick#h] > 12
		TaskValueSet,tick,h1,[tick#h]-12
	Elseif [tick#h] = 0
		TaskValueSet,tick,h1,12
	Else
	Endif
	NeoPixelLine,[tick#h1],12,25,25,0
	NeoPixelLine,1,[tick#h1],25,25,60
	If [tick#m] < 5
		TaskValueSet,tick,m1,12
	Else
		TaskValueSet,tick,m1,[tick#m]/5
	Endif
	NeoPixel,[tick#m1],180,20,40
Colors are not as easy to take a picture from. Seems that the SmartPhone- CAM have problems with that. But I hope you can see what I mean
DLzG
Micha
Re: NeoPixel (WS2812b) stability
#2 Post by Ath » 11 Jan 2023, 12:21
Besides checking the wiring (I assume you have that covered), you could install the neopixel 1M build (either Domoticz or FHEM/HA)
When using the NeoPixel (BusFX) plugin, there is a nfx,simpleclock,... command that can configure the pixels to behave like a clock, like you are trying to do from rules. That may work more stable.
M*I*B
#3 Post by M*I*B » 11 Jan 2023, 12:27
... the wiring is ok and short (10cm).
The hint with the special build I will check out right now... Thanx for that...
But just out of interest: What's the problem with that here? Just timing trouble while sending the commands to the stripe?
DLzG
Micha
#4 Post by TD-er » 11 Jan 2023, 12:57
How did you connect the data pin to the ESP?
Via a transistor, acting as a level converter?
If not, then it might be that the 3V3 level from the ESP isn't enough to trigger all LEDs.
Maybe also use a strong(er) pull resistor to make the level more clear and switching faster between levels.
After all, it is a relatively high frequency and also the data line may act as an antenna on a longer cable.
M*I*B
#5 Post by M*I*B » 11 Jan 2023, 13:11
... jepp, I use a digital FET as levelshifter ... And yes, that creates many QRM on 2m/70cm and even more on shortwave!!!
Will be a good idea to insert some RF choke and shield the whole thing as good as possible...
Meanwhile I have flash the special build (FHEM). The NeoPixel Ring Clock module is made for 60 LED? And also it isn't possible to change the color of the ticks? Or am I wrong?
I will try the fx then... looks good for now to increase the WAF :lol:
DLzG
Micha
#6 Post by Ath » 11 Jan 2023, 13:59
The NeoPixel BusFX plugin can be set to any number of Pixels (up to 300, AFAIR), but as long as you have a multiple of 12 (or you could try with 4 :lol:) the clock should be working just fine
M*I*B
#7 Post by M*I*B » 11 Jan 2023, 14:33
... ok, with 4 LED I better use a4 Relays and 4 15kW Beams that my neighbors als have some fun at night :lol: :lol: :lol:
EDIT:
Ok, that's crazy... I have forget that the 07S have 4M instead of 1M and used the 1M 1st. After rewriting my little rule to NFX all goes well as expected...
Then while dinner I remember about the 4M 07S and flashed the NeoPixel mega 4M.
So now the same rule don't work anymore... see the last line here...
359847: EVENT: Clock#Time=Wed,14:52
359889: ACT  : TaskValueSet,tick,h,14
359906: ACT  : TaskValueSet,tick,m,52
359916: ACT  : TaskValueSet,tick,h1,14-12
359933: ACT  : TaskValueSet,tick,m1,52/5
359939: ACT  : nfx,line,2,12,606000
359941: NeoPixelBusFX: Set 96/96/0
359947: ACT  : nfx,line,1,2,000080
359949: NeoPixelBusFX: Set 0/0/128
359955: ACT  : nfx,one,2,00A000
359957: NeoPixelBusFX: Set 0/160/0
359961: ACT  : Endon
359962: Command unknown: Endon
359962: Command unknown: Endon :o :? :?:
EDIT 2:
looks like that I have killed the 1st 07S while flashing to death :lol:
DLzG
Micha
#8 Post by TD-er » 11 Jan 2023, 15:34
Command unknown "endon" is probably just a syntax error.
And it is possible the 1M firmware was storing the WiFi config data at a different position on the flash.
So maybe you should flash a 'blank' image (containing only 0xFF) to it and flash the 4M build to it.
M*I*B
#9 Post by M*I*B » 11 Jan 2023, 16:10
... nope ... the 07S is death ... not flashable anymore ... I take a new one; have enough of them 8-)
DLzG
Micha
#10 Post by TD-er » 11 Jan 2023, 16:38
Maybe static discharge at pins that don't like it?
M*I*B
#11 Post by M*I*B » 11 Jan 2023, 16:41
... maybe .. or just to write to often so that the flash are broken ... But doesn't matter: Death is death :lol:
BTW:
that "Endon" don't work also like "If", "Elseif" or any other with the 1st letter capitalized. The former bin have no problems with it and also a colored gui with code completion, but not the NeoPixel image ... Here I have to rite all in lower-case
DLzG
Micha
#12 Post by TD-er » 11 Jan 2023, 17:13
huh? That's for sure a bug.
Will look into it.
M*I*B
#13 Post by M*I*B » 11 Jan 2023, 17:16
... wait a moment. I have just download the ESP_Easy_mega_20230111_neopixel_ESP8266_4M1M Jan 11 2023 Let#s see if that present here also... Moment...
Ok, not in the last build/merge... Can also be that my broken 07S have create that. I can't say for sure and can't reproduce it anymore (already in the bin)
DLzG
Micha
#14 Post by TD-er » 11 Jan 2023, 17:19
Just tested with these impressively complex rules:
On  Clock#Time=All,**:** Do
  LogEntry,'"Just testing...."'
And it seems to work just fine.
M*I*B
#15 Post by M*I*B » 11 Jan 2023, 17:21
... you are to fast and don't know the word "wait" hu? :lol: :lol: :lol:
DLzG
Micha
#16 Post by TD-er » 11 Jan 2023, 18:23
M*I*B wrote: 11 Jan 2023, 17:21 ... you are to fast and don't know the word "wait" hu? :lol: :lol: :lol:
Sure I do, I now already waited 2 minutes to reply ;)
