I'm back.
Unfortunately, the problem still occurs, but not as often.
I removed fading from pwm, disabled switch device (task 3) and minimized rules.
Rules:
On System#Boot do
TaskValueSet 4,1,20
TaskValueSet 4,3,205
TaskValueSet 4,2,0
let,1,0
let,2,0
Publish %sysname%/Inf,"Uruchomienie"
on Wifi#Connected do
Publish %sysname%/Inf,'{"A":"Polaczenie do Wi-fi","T":"%lcltime%"}'
on UstawSile do
Publish %sysname%/Inf,'{"A":"Siła świecenia - [Zmienna#Sila]","T":"%lcltime%"}'
if %eventvalue% > 100 or %eventvalue% < 0
TaskValueSet 4,1,100
TaskValueSet 4,3,1023
Publish %sysname%/UstawSile,100
TaskValueSet 4,1,%eventvalue%
TaskValueSet 4,3,[Zmienna#Sila]*1023/100
Publish %sysname%/UstawSile,[Zmienna#Sila]
if [Zmienna#Swieci] = 1
AsyncEvent Zapal
on Zapal do
pwm,14,[Zmienna#Wartosc]
TaskValueSet 4,2,1
Publish %sysname%/Zmienna/Swieci,[Zmienna#Swieci]
on Zgas do
pwm,14,0
TaskValueSet,4,2,0
Debug Log: (FreeMem 18648 --> 3312, then mqtt connection lost, wifi reconnect)
WD : Uptime 125 ConnectFailures 0 FreeMem 18648 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:34:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.21 loopCounterMax: 309278 loopCounterLast: 211806
Jan 11 15:34:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 211806/1982/9/89.85
Jan 11 15:34:51 ESP-TVLED EspEasy: WD : Uptime 125 ConnectFailures 0 FreeMem 18648 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:34:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.72 loopCounterMax: 309278 loopCounterLast: 211027
Jan 11 15:34:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 211027/1982/9/89.79
Jan 11 15:35:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:35
Jan 11 15:35:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:35 Processing time:5 milliSeconds
Jan 11 15:35:21 ESP-TVLED EspEasy: WD : Uptime 126 ConnectFailures 0 FreeMem 18648 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:35:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.10 loopCounterMax: 309278 loopCounterLast: 211987
Jan 11 15:35:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 211987/1982/9/89.89
Jan 11 15:35:51 ESP-TVLED EspEasy: WD : Uptime 126 ConnectFailures 0 FreeMem 18648 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:35:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.17 loopCounterMax: 309278 loopCounterLast: 211818
Jan 11 15:35:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 211818/1982/9/89.89
Jan 11 15:36:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:36
Jan 11 15:36:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:36 Processing time:5 milliSeconds
Jan 11 15:36:21 ESP-TVLED EspEasy: WD : Uptime 127 ConnectFailures 0 FreeMem 18624 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:36:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.61 loopCounterMax: 309278 loopCounterLast: 211211
Jan 11 15:36:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 211211/1982/9/89.74
Jan 11 15:36:51 ESP-TVLED EspEasy: WD : Uptime 127 ConnectFailures 0 FreeMem 18576 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:36:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.85 loopCounterMax: 309278 loopCounterLast: 210821
Jan 11 15:36:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210821/1982/9/89.75
Jan 11 15:37:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:37
Jan 11 15:37:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:37 Processing time:5 milliSeconds
Jan 11 15:37:21 ESP-TVLED EspEasy: WD : Uptime 128 ConnectFailures 0 FreeMem 18480 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:37:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.06 loopCounterMax: 309278 loopCounterLast: 210548
Jan 11 15:37:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210548/1982/9/89.80
Jan 11 15:37:51 ESP-TVLED EspEasy: WD : Uptime 128 ConnectFailures 0 FreeMem 18456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:37:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.44 loopCounterMax: 309278 loopCounterLast: 211448
Jan 11 15:37:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 211448/1982/9/89.89
Jan 11 15:38:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:38
Jan 11 15:38:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:38 Processing time:4 milliSeconds
Jan 11 15:38:21 ESP-TVLED EspEasy: WD : Uptime 129 ConnectFailures 0 FreeMem 18456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:38:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.72 loopCounterMax: 309278 loopCounterLast: 211054
Jan 11 15:38:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 211054/1982/9/89.79
Jan 11 15:38:51 ESP-TVLED EspEasy: WD : Uptime 129 ConnectFailures 0 FreeMem 18408 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:38:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.33 loopCounterMax: 309278 loopCounterLast: 211602
Jan 11 15:38:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 211602/1982/9/89.82
Jan 11 15:39:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:39
Jan 11 15:39:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:39 Processing time:4 milliSeconds
Jan 11 15:39:21 ESP-TVLED EspEasy: WD : Uptime 130 ConnectFailures 0 FreeMem 18240 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:39:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.54 loopCounterMax: 309278 loopCounterLast: 209839
Jan 11 15:39:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 209839/1982/9/89.74
Jan 11 15:39:51 ESP-TVLED EspEasy: WD : Uptime 130 ConnectFailures 0 FreeMem 18144 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:39:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 136.71 loopCounterMax: 309278 loopCounterLast: 212532
Jan 11 15:39:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 212532/1982/9/89.86
Jan 11 15:40:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:40
Jan 11 15:40:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:40 Processing time:5 milliSeconds
Jan 11 15:40:21 ESP-TVLED EspEasy: WD : Uptime 131 ConnectFailures 0 FreeMem 18144 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:40:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.86 loopCounterMax: 309278 loopCounterLast: 210847
Jan 11 15:40:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210847/1982/9/89.79
Jan 11 15:40:51 ESP-TVLED EspEasy: WD : Uptime 131 ConnectFailures 0 FreeMem 18096 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:40:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.83 loopCounterMax: 309278 loopCounterLast: 210861
Jan 11 15:40:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210861/1982/9/89.89
Jan 11 15:41:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:41
Jan 11 15:41:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:41 Processing time:4 milliSeconds
Jan 11 15:41:21 ESP-TVLED EspEasy: WD : Uptime 132 ConnectFailures 0 FreeMem 17808 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:41:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.12 loopCounterMax: 309278 loopCounterLast: 210474
Jan 11 15:41:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210474/1982/9/89.68
Jan 11 15:41:51 ESP-TVLED EspEasy: WD : Uptime 132 ConnectFailures 0 FreeMem 17544 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:41:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.80 loopCounterMax: 309278 loopCounterLast: 210902
Jan 11 15:41:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210902/1982/9/89.85
Jan 11 15:42:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:42
Jan 11 15:42:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:42 Processing time:5 milliSeconds
Jan 11 15:42:21 ESP-TVLED EspEasy: WD : Uptime 133 ConnectFailures 0 FreeMem 17520 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:42:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.83 loopCounterMax: 309278 loopCounterLast: 210856
Jan 11 15:42:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210856/1982/9/89.86
Jan 11 15:42:51 ESP-TVLED EspEasy: WD : Uptime 133 ConnectFailures 0 FreeMem 17472 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:42:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.84 loopCounterMax: 309278 loopCounterLast: 210840
Jan 11 15:42:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210840/1982/9/89.75
Jan 11 15:43:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:43
Jan 11 15:43:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:43 Processing time:5 milliSeconds
Jan 11 15:43:21 ESP-TVLED EspEasy: WD : Uptime 134 ConnectFailures 0 FreeMem 17040 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:43:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.60 loopCounterMax: 309278 loopCounterLast: 211220
Jan 11 15:43:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 211220/1982/9/89.79
Jan 11 15:43:51 ESP-TVLED EspEasy: WD : Uptime 134 ConnectFailures 0 FreeMem 16464 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:43:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.07 loopCounterMax: 309278 loopCounterLast: 210500
Jan 11 15:43:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210500/1982/9/89.83
Jan 11 15:44:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:44
Jan 11 15:44:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:44 Processing time:5 milliSeconds
Jan 11 15:44:21 ESP-TVLED EspEasy: WD : Uptime 135 ConnectFailures 0 FreeMem 16320 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:44:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.02 loopCounterMax: 309278 loopCounterLast: 210568
Jan 11 15:44:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210568/1982/9/89.76
Jan 11 15:44:51 ESP-TVLED EspEasy: WD : Uptime 135 ConnectFailures 0 FreeMem 16272 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:44:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.03 loopCounterMax: 309278 loopCounterLast: 210601
Jan 11 15:44:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210601/1982/9/89.87
Jan 11 15:45:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:45
Jan 11 15:45:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:45 Processing time:5 milliSeconds
Jan 11 15:45:21 ESP-TVLED EspEasy: WD : Uptime 136 ConnectFailures 0 FreeMem 15624 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:45:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.36 loopCounterMax: 309278 loopCounterLast: 210110
Jan 11 15:45:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210110/1982/9/89.68
Jan 11 15:45:51 ESP-TVLED EspEasy: WD : Uptime 136 ConnectFailures 0 FreeMem 14448 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:45:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.39 loopCounterMax: 309278 loopCounterLast: 210026
Jan 11 15:45:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210026/1982/9/89.73
Jan 11 15:46:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:46
Jan 11 15:46:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:46 Processing time:5 milliSeconds
Jan 11 15:46:21 ESP-TVLED EspEasy: WD : Uptime 137 ConnectFailures 0 FreeMem 13920 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:46:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.02 loopCounterMax: 309278 loopCounterLast: 210610
Jan 11 15:46:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210610/1982/9/89.75
Jan 11 15:46:51 ESP-TVLED EspEasy: WD : Uptime 137 ConnectFailures 0 FreeMem 13848 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:46:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.91 loopCounterMax: 309278 loopCounterLast: 210741
Jan 11 15:46:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210741/1982/9/89.65
Jan 11 15:47:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:47
Jan 11 15:47:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:47 Processing time:5 milliSeconds
Jan 11 15:47:21 ESP-TVLED EspEasy: WD : Uptime 138 ConnectFailures 0 FreeMem 12960 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:47:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.65 loopCounterMax: 309278 loopCounterLast: 209688
Jan 11 15:47:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 209688/1982/9/89.62
Jan 11 15:47:51 ESP-TVLED EspEasy: WD : Uptime 138 ConnectFailures 0 FreeMem 11160 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:47:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.45 loopCounterMax: 309278 loopCounterLast: 209933
Jan 11 15:47:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 209933/1982/9/89.53
Jan 11 15:48:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:48
Jan 11 15:48:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:48 Processing time:5 milliSeconds
Jan 11 15:48:21 ESP-TVLED EspEasy: WD : Uptime 139 ConnectFailures 0 FreeMem 9840 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:48:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.60 loopCounterMax: 309278 loopCounterLast: 209759
Jan 11 15:48:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 209759/1982/9/89.62
Jan 11 15:48:51 ESP-TVLED EspEasy: WD : Uptime 139 ConnectFailures 0 FreeMem 9600 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:48:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.27 loopCounterMax: 309278 loopCounterLast: 210206
Jan 11 15:48:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210206/1982/9/89.68
Jan 11 15:49:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:49
Jan 11 15:49:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:49 Processing time:5 milliSeconds
Jan 11 15:49:21 ESP-TVLED EspEasy: WD : Uptime 140 ConnectFailures 0 FreeMem 8496 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:49:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 137.83 loopCounterMax: 309278 loopCounterLast: 210832
Jan 11 15:49:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210832/1982/9/89.38
Jan 11 15:49:51 ESP-TVLED EspEasy: WD : Uptime 140 ConnectFailures 0 FreeMem 6192 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:49:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.60 loopCounterMax: 309278 loopCounterLast: 209736
Jan 11 15:49:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 209736/1982/9/89.47
Jan 11 15:50:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:50
Jan 11 15:50:01 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:50 Processing time:8 milliSeconds
Jan 11 15:50:21 ESP-TVLED EspEasy: WD : Uptime 141 ConnectFailures 0 FreeMem 4152 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:50:22 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.14 loopCounterMax: 309278 loopCounterLast: 210453
Jan 11 15:50:22 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 210453/1982/9/89.30
Jan 11 15:50:51 ESP-TVLED EspEasy: WD : Uptime 141 ConnectFailures 0 FreeMem 3312 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:50:52 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 356249 avgLoopDuration: 138.72 loopCounterMax: 309278 loopCounterLast: 209606
Jan 11 15:50:52 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 209606/1982/9/89.45
Jan 11 15:50:58 ESP-TVLED EspEasy: MQTT : Connection lost, state: Disconnected
Jan 11 15:50:58 ESP-TVLED EspEasy: Read settings: ControllerSettings index: 0
Jan 11 15:51:21 ESP-TVLED EspEasy: WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: IP
Jan 11 15:51:21 ESP-TVLED EspEasy: firstLoopConnectionsEstablished
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: WiFi#Connected
Jan 11 15:51:21 ESP-TVLED EspEasy: RuleDebug: 001: on Wifi#Connected do
Jan 11 15:51:21 ESP-TVLED EspEasy: Bitwise: {a:Polaczenie do Wi-fi:T:"1970-01-01 00:00:12"}
Jan 11 15:51:21 ESP-TVLED EspEasy: RuleDebug: 000: Publish ESP_TVLED/Inf,'{"A":"Polaczenie do Wi-fi","T":"1970-01-01 00:00:12"}'
Jan 11 15:51:21 ESP-TVLED EspEasy: ACT : Publish ESP_TVLED/Inf,'{"A":"Polaczenie do Wi-fi","T":"1970-01-01 00:00:12"}'
Jan 11 15:51:21 ESP-TVLED EspEasy: Command: Publish
Jan 11 15:51:21 ESP-TVLED EspEasy: Publish ESP_TVLED/Inf,'{"A":"Polaczenie do Wi-fi","T":"1970-01-01 00:00:12"}'
Jan 11 15:51:21 ESP-TVLED EspEasy: Par1: 0 Par2: 0 Par3: 0 Par4: 0 Par5: 0
Jan 11 15:51:21 ESP-TVLED EspEasy: Publish: ESP_TVLED/Inf{"A":"Polaczenie do Wi-fi","T":"1970-01-01 00:00:12"}
Jan 11 15:51:21 ESP-TVLED EspEasy: Read settings: ControllerSettings index: 0
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: WiFi#Connected Processing time:76 milliSeconds
Jan 11 15:51:21 ESP-TVLED EspEasy: WiFi : Missed connected event
Jan 11 15:51:21 ESP-TVLED EspEasy: WIFI : Connected! AP: HypersNet_2.4G (00:72:63:30:00:36) Ch: 6 Duration: 984 ms
Jan 11 15:51:21 ESP-TVLED EspEasy: WiFi : WiFi services initialized
Jan 11 15:51:21 ESP-TVLED EspEasy: NTP : NTP host 0.pl.pool.ntp.org (185.231.150.1) queried
Jan 11 15:51:21 ESP-TVLED EspEasy: NTP : NTP replied: delay 30 mSec Accuracy increased by 0.493 seconds
Jan 11 15:51:21 ESP-TVLED EspEasy: Time set to 1673448681.493
Jan 11 15:51:21 ESP-TVLED EspEasy: Current Time Zone: DST time start: 2023-03-26 02:00:00 offset: 120 min STD time start: 2023-10-29 03:00:00 offset: 60 min
Jan 11 15:51:21 ESP-TVLED EspEasy: Local time: 2023-01-11 15:51:21
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: WiFi#ChangedAccesspoint
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: WiFi#ChangedAccesspoint Processing time:6 milliSeconds
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: WiFi#ChangedWiFichannel
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: WiFi#ChangedWiFichannel Processing time:5 milliSeconds
Jan 11 15:51:21 ESP-TVLED EspEasy: MQTT : Intentional reconnect
Jan 11 15:51:21 ESP-TVLED EspEasy: MQTT : Connected to broker with client ID: ESP_TVLED_0
Jan 11 15:51:21 ESP-TVLED EspEasy: Subscribed to: ESP_TVLED/#
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:51
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:51 Processing time:5 milliSeconds
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: Time#Initialized
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: Time#Initialized Processing time:5 milliSeconds
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: MQTT#Connected
Jan 11 15:51:21 ESP-TVLED EspEasy: EVENT: MQTT#Connected Processing time:5 milliSeconds
Jan 11 15:51:21 ESP-TVLED EspEasy: LoopStats: shortestLoop: 120 longestLoop: 326652 avgLoopDuration: 2157.91 loopCounterMax: 250000 loopCounterLast: 1025
Jan 11 15:51:21 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 1021/73/9/1.01
Jan 11 15:51:22 ESP-TVLED EspEasy: EVENT: UstawSile=20
Jan 11 15:51:22 ESP-TVLED EspEasy: RuleDebug: 001: on UstawSile do
Jan 11 15:51:22 ESP-TVLED EspEasy: Read settings: TaskSettings index: 0
Jan 11 15:51:22 ESP-TVLED EspEasy: Read settings: TaskSettings index: 1
Jan 11 15:51:22 ESP-TVLED EspEasy: Read settings: TaskSettings index: 2
Jan 11 15:51:22 ESP-TVLED EspEasy: Read settings: TaskSettings index: 3
Jan 11 15:51:22 ESP-TVLED EspEasy: DEBUG DEV: Parsed String='Publish ESP_TVLED/Inf,'{"A":"Siła świecenia - 20'
Jan 11 15:51:22 ESP-TVLED EspEasy: Bitwise: {a:Siła świecenia - 20:T:"2023-01-11 15:51:21"}
Jan 11 15:51:22 ESP-TVLED EspEasy: RuleDebug: 000: Publish ESP_TVLED/Inf,'{"A":"Siła świecenia - 20","T":"2023-01-11 15:51:21"}'
Jan 11 15:51:22 ESP-TVLED EspEasy: Publish ESP_TVLED/Inf,'{"A":"Siła świecenia - 20","T":"2023-01-11 15:51:21"}'
Jan 11 15:51:22 ESP-TVLED EspEasy: Publish: ESP_TVLED/Inf{"A":"Siła świecenia - 20","T":"2023-01-11 15:51:21"}
Jan 11 15:51:22 ESP-TVLED EspEasy: RuleDebug: 000: if 20 > 100 or 20 < 0
Jan 11 15:51:22 ESP-TVLED EspEasy: timeStringToSeconds: "20" --> invalid
Jan 11 15:51:22 ESP-TVLED EspEasy: conditionMatch: "20 > 100 or 20 < 0" --> "20" > "100" --> false (20 > 100)
Jan 11 15:51:22 ESP-TVLED EspEasy: conditionMatchExtended: false "20 > 100 or 20 < 0"
Jan 11 15:51:22 ESP-TVLED EspEasy: Lev.1: [if false || false]=false
Jan 11 15:51:22 ESP-TVLED EspEasy: RuleDebug: 000: TaskValueSet 4,1,20
Jan 11 15:51:22 ESP-TVLED EspEasy: Command: TaskValueSet
Jan 11 15:51:22 ESP-TVLED EspEasy: Par1: 0 Par2: 20 Par3: 0 Par4: 0 Par5: 0
Jan 11 15:51:22 ESP-TVLED EspEasy: ACT : Publish ESP_TVLED/Inf,'{"A":"Siła świecenia - 20","T":"2023-01-11 15:51:21"}'
Jan 11 15:51:22 ESP-TVLED EspEasy: Command: Publish
Jan 11 15:51:50 ESP-TVLED EspEasy: WD : Uptime 1 ConnectFailures 0 FreeMem 17888 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:51:51 ESP-TVLED EspEasy: LoopStats: shortestLoop: 120 longestLoop: 350767 avgLoopDuration: 146.23 loopCounterMax: 250000 loopCounterLast: 198524
Jan 11 15:51:51 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 198524/1969/9/89.67
Jan 11 15:52:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:52
Jan 11 15:52:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:52 Processing time:5 milliSeconds
Jan 11 15:52:20 ESP-TVLED EspEasy: WD : Uptime 1 ConnectFailures 0 FreeMem 17864 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:52:21 ESP-TVLED EspEasy: LoopStats: shortestLoop: 120 longestLoop: 350767 avgLoopDuration: 144.01 loopCounterMax: 250000 loopCounterLast: 201507
Jan 11 15:52:21 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 201507/1982/9/89.70
Jan 11 15:52:50 ESP-TVLED EspEasy: WD : Uptime 2 ConnectFailures 0 FreeMem 17840 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:52:51 ESP-TVLED EspEasy: LoopStats: shortestLoop: 120 longestLoop: 350767 avgLoopDuration: 143.98 loopCounterMax: 250000 loopCounterLast: 201609
Jan 11 15:52:51 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 201609/1982/9/89.77
Jan 11 15:53:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:53
Jan 11 15:53:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:53 Processing time:5 milliSeconds
Jan 11 15:53:20 ESP-TVLED EspEasy: WD : Uptime 2 ConnectFailures 0 FreeMem 17840 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:53:21 ESP-TVLED EspEasy: LoopStats: shortestLoop: 120 longestLoop: 350767 avgLoopDuration: 144.09 loopCounterMax: 250000 loopCounterLast: 201412
Jan 11 15:53:21 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 201412/1982/9/89.72
Jan 11 15:53:50 ESP-TVLED EspEasy: WD : Uptime 3 ConnectFailures 0 FreeMem 17840 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:53:51 ESP-TVLED EspEasy: LoopStats: shortestLoop: 120 longestLoop: 350767 avgLoopDuration: 144.49 loopCounterMax: 250000 loopCounterLast: 200915
Jan 11 15:53:51 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 200915/1982/9/89.79
Jan 11 15:54:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:54
Jan 11 15:54:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:54 Processing time:5 milliSeconds
Jan 11 15:54:20 ESP-TVLED EspEasy: WD : Uptime 3 ConnectFailures 0 FreeMem 17792 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:54:21 ESP-TVLED EspEasy: LoopStats: shortestLoop: 120 longestLoop: 350767 avgLoopDuration: 157.15 loopCounterMax: 250000 loopCounterLast: 185720
Jan 11 15:54:21 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 185720/1982/9/89.63
Jan 11 15:54:50 ESP-TVLED EspEasy: WD : Uptime 4 ConnectFailures 0 FreeMem 17744 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:54:51 ESP-TVLED EspEasy: LoopStats: shortestLoop: 120 longestLoop: 350767 avgLoopDuration: 156.96 loopCounterMax: 250000 loopCounterLast: 185965
Jan 11 15:54:51 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 185965/1982/9/89.62
Jan 11 15:55:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:55
Jan 11 15:55:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:55 Processing time:5 milliSeconds
Jan 11 15:55:20 ESP-TVLED EspEasy: WD : Uptime 4 ConnectFailures 0 FreeMem 17720 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:55:21 ESP-TVLED EspEasy: LoopStats: shortestLoop: 120 longestLoop: 350767 avgLoopDuration: 156.87 loopCounterMax: 250000 loopCounterLast: 186041
Jan 11 15:55:21 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 186041/1982/9/89.67
Jan 11 15:55:50 ESP-TVLED EspEasy: WD : Uptime 5 ConnectFailures 0 FreeMem 17720 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:55:51 ESP-TVLED EspEasy: LoopStats: shortestLoop: 120 longestLoop: 350767 avgLoopDuration: 157.06 loopCounterMax: 250000 loopCounterLast: 185846
Jan 11 15:55:51 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 185846/1982/9/89.64
Jan 11 15:56:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:56
Jan 11 15:56:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:56 Processing time:5 milliSeconds
Jan 11 15:56:20 ESP-TVLED EspEasy: WD : Uptime 5 ConnectFailures 0 FreeMem 18136 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:56:21 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 350767 avgLoopDuration: 155.77 loopCounterMax: 309278 loopCounterLast: 187283
Jan 11 15:56:21 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 187283/1978/9/89.62
Jan 11 15:56:50 ESP-TVLED EspEasy: WD : Uptime 6 ConnectFailures 0 FreeMem 18360 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Jan 11 15:56:51 ESP-TVLED EspEasy: LoopStats: shortestLoop: 97 longestLoop: 350767 avgLoopDuration: 137.11 loopCounterMax: 309278 loopCounterLast: 211795
Jan 11 15:56:51 ESP-TVLED EspEasy: Scheduler stats: (called/tasks/max_length/idle%) 211795/1982/9/89.89
Jan 11 15:57:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:57
Jan 11 15:57:00 ESP-TVLED EspEasy: EVENT: Clock#Time=Wed,15:57 Processing time:5 milliSeconds
Thank you in advance for any new idea.
