I've tried installing "ESP_Easy_mega_20221224_normal_ESP32_4M316k" on 2 different WROOM ESP32's (non S2) and both flash correctly, but give FS errors and hang.
Can someone give some advice please?
Ian
Using '/dev/cu.usbserial-0001' as serial port.
[16:43:15]INIT : Booting version: ESP_Easy_mega_20221224_normal_ESP32_4M316k_ETH, (GitHub Actions) mega-20221224_35f2ff8 (ESP32 SDK v4.4.3)
Connecting...[16:43:15]6964 : Info ets Jun 8 2016 00:22:57
[16:43:15]
[16:43:15]rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
..Serial port closed!
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting...................
Detecting chip type... ESP32
Connecting....................
Chip Info:
- Chip Family: ESP32
- Chip Model: ESP32-D0WDQ6 (revision 0)
- Number of Cores: 2
- Max CPU Frequency: 80MHz
- Has Bluetooth: YES
- Has Embedded Flash: NO
- Has Factory-Calibrated ADC: NO
- MAC Address: 24:0A:C4:81:AC:40
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
- Flash Size: 4MB
- Flash Mode: dout
- Flash Frequency: 40MHz
Erasing flash (this may take a while)...
Chip erase completed successfully in 4.0s
Flash will be erased from 0x00001000 to 0x00004fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x0013dfff...
Compressed 15872 bytes to 10320...
Writing at 0x00001000... (100 %)Wrote 15872 bytes (10320 compressed) at 0x00001000 in 0.4 seconds (effective 332.1 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 144...
Writing at 0x00008000... (100 %)Wrote 3072 bytes (144 compressed) at 0x00008000 in 0.0 seconds (effective 514.0 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 902.2 kbit/s)...
Compressed 1234672 bytes to 842446...
Writing at 0x0013b15b... (100 %)Wrote 1234672 bytes (842446 compressed) at 0x00010000 in 20.1 seconds (effective 491.0 kbit/s)...
Leaving...
Hard Resetting...
Hard resetting via RTS pin...
Done! Flashing is complete!
Showing logs:
[16:43:55]ets Jun 8 2016 00:22:57
[16:43:55]
[16:43:55]rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[16:43:55]configsip: 0, SPIWP:0xee
[16:43:55]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[16:43:55]mode:DOUT, clock div:2
[16:43:55]load:0x3fff0018,len:4
[16:43:55]load:0x3fff001c,len:1044
[16:43:55]load:0x40078000,len:8896
[16:43:55]load:0x40080400,len:5828
[16:43:55]entry 0x400806ac
[16:43:56]U32 : Info :
[16:43:56]
[16:43:56]INIT : Booting version: HEAD_56d3225 (ESP32 SDK v4.4.1)
[16:43:56]33 : Info : INIT : Free RAM:282864
[16:43:57]35 : Info : INIT : Cold Boot - Restart Reason: CPU0: RTC Watch dog reset digital core and rtc module CPU1: for APP CPU, reseted by PRO CPU
[16:43:57]36 : Info : FS : Mounting...
[16:43:57]FS : Mount failed
[16:43:58]37 : Error : FS : Mount failed
[16:43:58]RESET: Resetting factory defaults... using default settings
[16:43:58]RESET: Warm boot, reset count: 0
[16:43:58]RESET: formatting...
[16:44:15]RESET: formatting done...
[16:44:16]18990 : Error : FS : Error while reading/writing config.dat in 12237
[16:44:16]19810 : Error : FS : Error while reading/writing security.dat in 12237
[16:44:16]19943 : Info : SaveToFile: free stack: 7416
[16:44:16]20004 : Info : FILE : Saved config.dat offset: 8192 size: 820
[16:44:16]20005 : Info : SaveToFile: free stack after: 7416
[16:44:16]20006 : Info : SaveToFile: free stack: 7448
[16:44:16]20088 : Info : FILE : Saved config.dat offset: 0 size: 3004
[16:44:16]20089 : Info : SaveToFile: free stack after: 7448
[16:44:16]20090 : Info : SaveToFile: free stack: 7256
[16:44:16]20153 : Info : FILE : Saved security.dat offset: 0 size: 593
[16:44:16]20154 : Info : SaveToFile: free stack after: 7256
[16:44:16]20156 : Info : SaveToFile: free stack: 6888
[16:44:17]20159 : Error : FS : Error while reading/writing security.dat in 12318
[16:44:17]RESET: Successful, rebooting. (you might need to press the reset button if you've just flashed the firmware)
[16:44:18]21345 : Inets Jun 8 2016 00:22:57
[16:44:18]
[16:44:18]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[16:44:18]configsip: 0, SPIWP:0xee
[16:44:18]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[16:44:18]mode:DOUT, clock div:2
[16:44:18]load:0x3fff0018,len:4
[16:44:18]load:0x3fff001c,len:1044
[16:44:18]load:0x40078000,len:8896
[16:44:18]load:0x40080400,len:5828
[16:44:18]entry 0x400806ac
[16:44:18]U36 : Info :
[16:44:18]
[16:44:18]INIT : Booting version: HEAD_56d3225 (ESP32 SDK v4.4.1)
[16:44:18]37 : Info : INIT : Free RAM:282564
[16:44:33]39 : Info : INIT : Soft Reboot #1 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 21 - Restart Reason: CPU0: Softwa15196 : Info : SaveToFile: free stack: 7528
[16:44:33]15257 : Info : FILE : Saved config.dat offset: 8192 size: 820
[16:44:33]15258 : Info : SaveToFile: free stack after: 7528
[16:44:33]15259 : Info : SaveToFile: free stack: 7560
[16:44:33]15291 : Info : FILE : Saved config.dat offset: 0 size: 3004
[16:44:33]15292 : Info : SaveToFile: free stack after: 7560
[16:44:33]15293 : Info : SaveToFile: free stack: 7368
[16:44:33]15353 : Info : FILE : Saved security.dat offset: 0 size: 593
[16:44:33]15354 : Info : SaveToFile: free stack after: 7368
[16:44:33]15356 : Info : SaveToFile: free stack: 7000
[16:44:34]15359 : Error : FS : Error while reading/writing security.dat in 12318
[16:44:34]RESET: Successful, rebooting. (you might need to press the reset button if you've just flashed the firmware)
[16:44:34]16379 : Infets Jun 8 2016 00:22:57
[16:44:34]
[16:44:34]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[16:44:34]configsip: 0, SPIWP:0xee
[16:44:34]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[16:44:34]mode:DOUT, clock div:2
[16:44:34]load:0x3fff0018,len:4
[16:44:34]load:0x3fff001c,len:1044
[16:44:34]load:0x40078000,len:8896
[16:44:34]load:0x40080400,len:5828
[16:44:34]entry 0x400806ac
[16:44:44]ets Jun 8 2016 00:22:57
[16:44:44]
[16:44:44]rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[16:44:44]configsip: 0, SPIWP:0xee
[16:44:44]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[16:44:44]mode:DOUT, clock div:2
[16:44:44]load:0x3fff0018,len:4
[16:44:44]load:0x3fff001c,len:1044
[16:44:44]load:0x40078000,len:8896
[16:44:44]load:0x40080400,len:5828
[16:44:44]entry 0x400806ac
[16:44:44]U36 : Info :
[16:44:44]
[16:44:44]INIT : Booting version: HEAD_56d3225 (ESP32 SDK v4.4.1)
[16:44:44]37 : Info : INIT : Free RAM:282564
[16:44:59]39 : Info : INIT : Cold Boot #2 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 37 - Restart Reason: CPU0: RTC Watch14993 : Info : SaveToFile: free stack: 7528
[16:44:59]15052 : Info : FILE : Saved config.dat offset: 8192 size: 820
[16:44:59]15053 : Info : SaveToFile: free stack after: 7528
[16:44:59]15054 : Info : SaveToFile: free stack: 7560
[16:44:59]15086 : Info : FILE : Saved config.dat offset: 0 size: 3004
[16:44:59]15087 : Info : SaveToFile: free stack after: 7560
[16:44:59]15088 : Info : SaveToFile: free stack: 7368
[16:44:59]15146 : Info : FILE : Saved security.dat offset: 0 size: 593
[16:44:59]15147 : Info : SaveToFile: free stack after: 7368
[16:44:59]15149 : Info : SaveToFile: free stack: 7000
[16:45:00]15152 : Error : FS : Error while reading/writing security.dat in 12318
[16:45:01]RESET: Successful, rebooting. (you might need to press the reset button if you've just flashed the firmware)
[16:45:01]16172 : Inets Jun 8 2016 00:22:57
[16:45:01]
[16:45:01]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[16:45:01]configsip: 0, SPIWP:0xee
[16:45:01]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[16:45:01]mode:DOUT, clock div:2
[16:45:01]load:0x3fff0018,len:4
[16:45:01]load:0x3fff001c,len:1044
[16:45:01]load:0x40078000,len:8896
[16:45:01]load:0x40080400,len:5828
[16:45:01]entry 0x400806ac
[16:45:01]U36 : Info :
[16:45:01]
[16:45:01]INIT : Booting version: HEAD_56d3225 (ESP32 SDK v4.4.1)
[16:45:01]37 : Info : INIT : Free RAM:282564
