read the duty cycle value?
chromo23
#1 Post by chromo23 » 06 Dec 2022, 08:53
Good morning,
the duty cycle value used in the pwm command must be stored somewhere.
Is there a command to retrieve it?
Re: read the duty cycle value?
#2 Post by TD-er » 06 Dec 2022, 10:01
Doesn't it show at the pin state buffer page?
Not sure if that page is also/already available as JSON.
chromo23
#3 Post by chromo23 » 06 Dec 2022, 10:13
And is retrieving the value from there for further processing (sending it somewhere / rules) possible somehow?
it isn’t ...
#4 Post by TD-er » 06 Dec 2022, 10:16
Not right now.
But I guess it would make sense to make it available, like the pinstate is.
For example:
[Plugin#GPIO#Pinstate#13]
See: https://espeasy.readthedocs.io/en/lates ... ing-events
Then scroll up a bit...
judie07
#5 Post by judie07 » 26 Dec 2022, 17:02
Have you made any progress? ->viewtopic.php?p=61989#p61989
#6 Post by Ath » 26 Dec 2022, 23:28
I have created Pull request #4435 to enable the last set duty-cycle value to be retrieved for (internal) GPIO pins set to PWM or SERVO.
Users browsing this forum: No registered users and 35 guests
