I installed espeasy on 2 wemos D1 mini last year, no problem.
Today I am trying on 3 new wemos d1 mini card, but I am faced with a problem: I cannot connect it to my wifi network (which has not changed).
In Espeasy flasher, I enter the ssid, the password and the IP address, After the flash, the log tells me that everything is OK.
But when I restart the d1 mini, it does not take the entered IP address (such as 192.168.1.126) !!.
I have to connect to the 192.168.4.1, I then choose my wifi network, I enter the password , I validate ..... but it returns to the menu of the choice of wifi networks !!!
I tried with several different versions of espeasy: same result.
My wifi is generated by my asus rt-ax88u router in 2 G and 5 G.
I tried on 2 new wemos d1 mini: same result, impossible for it to connect to my wifi network after flashing
here is a flash log, everything looks normal, but it does not work
######2021-02-17######
#######0.04.007#######
######FLASH INFO######
BIN file: ESP_Easy_mega_20210114_normal_ESP8266_4M1M.bin
COM port: (COM4) USB-SERIAL CH340 (Port_#0002.Hub_#0001)
Baud rate: 115200
######POST FLASH######
Unit name: Wemos_3
Unit number:
Admin password:
WiFi SSID 1: ASUS_38_2G
WiFi password 1: xxxxxxx
WiFi SSID 2: ASUS_38_5G
WiFi password 2: xxxxxxxxx
IP: 192.168.1.126
######FLASH LOG######
[esptool.exe -vv -cd nodemcu -cb 115200 -cp COM4 -ca 0x00000 -cf "D:\CloudStation\PERSO\Personnel\Informatique\ESP EASY WEBOS MINI\ESPEasy_ESP82xx_mega-20210114\bin\ESP_Easy_mega_20210114_normal_ESP8266_4M1M.bin"]
[17/02/2021 19:24:31] esptool v0.4.12 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
[17/02/2021 19:24:31] setting board to nodemcu
[17/02/2021 19:24:31] setting baudrate from 115200 to 115200
[17/02/2021 19:24:31] setting port from to COM4
[17/02/2021 19:24:31] setting address from 0x00000000 to 0x00000000
[17/02/2021 19:24:31] espcomm_upload_file
[17/02/2021 19:24:31] espcomm_upload_mem
[17/02/2021 19:24:31] setting serial port timeouts to 1000 ms
[17/02/2021 19:24:31] opening bootloader
[17/02/2021 19:24:31] resetting board
[17/02/2021 19:24:31] trying to connect
[17/02/2021 19:24:31] flush start
[17/02/2021 19:24:31] setting serial port timeouts to 1 ms
[17/02/2021 19:24:31] flush complete
[17/02/2021 19:24:31] espcomm_send_command: sending command header
[17/02/2021 19:24:31] espcomm_send_command: sending command payload
[17/02/2021 19:24:31] read 0, requested 1
[17/02/2021 19:24:31] espcomm_send_command: receiving 2 bytes of data
[17/02/2021 19:24:31] Uploading 919840 bytes from D:\CloudStation\PERSO\Personnel\Informatique\ESP EASY WEBOS MINI\ESPEasy_ESP82xx_mega-20210114\bin\ESP_Easy_mega_20210114_normal_ESP8266_4M1M.bin to flash at 0x00000000
[17/02/2021 19:24:31] erasing flash
[17/02/2021 19:24:31] size: 0e0920 address: 000000
[17/02/2021 19:24:31] first_sector_index: 0
[17/02/2021 19:24:31] total_sector_count: 225
[17/02/2021 19:24:31] head_sector_count: 16
[17/02/2021 19:24:31] adjusted_sector_count: 209
[17/02/2021 19:24:31] erase_size: 0d1000
[17/02/2021 19:24:31] setting serial port timeouts to 15000 ms
[17/02/2021 19:24:31] writing flash
[17/02/2021 19:24:40] ................................................................................ [ 8% ]
[17/02/2021 19:24:48] ................................................................................ [ 17% ]
[17/02/2021 19:24:57] ................................................................................ [ 26% ]
[17/02/2021 19:25:06] ................................................................................ [ 35% ]
[17/02/2021 19:25:14] ................................................................................ [ 44% ]
[17/02/2021 19:25:23] ................................................................................ [ 53% ]
[17/02/2021 19:25:31] ................................................................................ [ 62% ]
[17/02/2021 19:25:40] ................................................................................ [ 71% ]
[17/02/2021 19:25:49] ................................................................................ [ 80% ]
[17/02/2021 19:25:57] ................................................................................ [ 88% ]
[17/02/2021 19:26:06] ................................................................................ [ 97% ]
[17/02/2021 19:26:08] ................... [ 100% ]
[17/02/2021 19:26:08] starting app without reboot
[17/02/2021 19:26:08] espcomm_send_command: sending command header
[17/02/2021 19:26:08] espcomm_send_command: sending command payload
[17/02/2021 19:26:08] espcomm_send_command: receiving 2 bytes of data
[17/02/2021 19:26:08] closing bootloader
[17/02/2021 19:26:08] flush start
[17/02/2021 19:26:08] setting serial port timeouts to 1 ms
[17/02/2021 19:26:08] setting serial port timeouts to 1000 ms
[17/02/2021 19:26:08] flush complete
[2021-02-17 19:26:08] DONE!
[2021-02-17 19:26:09] JOB COMPLETED, over and out!
