Good morning,
the duty cycle value used in the pwm command must be stored somewhere.
Is there a command to retrieve it?
read the duty cycle value?
Re: read the duty cycle value?
Doesn't it show at the pin state buffer page?
Not sure if that page is also/already available as JSON.
And is retrieving the value from there for further processing (sending it somewhere / rules) possible somehow?
it isn’t ...Not sure if that page is also/already available as JSON.
Not right now.
But I guess it would make sense to make it available, like the pinstate is.
For example:
See: https://espeasy.readthedocs.io/en/lates ... ing-events
Then scroll up a bit...
For example:
[Plugin#GPIO#Pinstate#13]
Have you made any progress? ->viewtopic.php?p=61989#p61989
Users browsing this forum: Ahrefs [Bot] and 49 guests
