Mqtt adafruit.io
Mqtt adafruit.io
In adafriit.io i have a toogle button and when i active it i receive this in log:
Command: feeds
1341366564: Command unknown: feeds,2357554,1
Or
Command: feeds
1341366564: Command unknown: feeds,2357554,0
how can i make a rule to change gpio?
Example that doesn't work
On feeds do
If %eventvalue1%=2357554
gpio,2,%eventvalue2%
Endif
Binary Filename: ESP_Easy_mega_20220809_collection_B_ESP8266_4M1M
ESP Board Name: Espressif Generic 1 ESPEasy 4M Flash 1M FS
Thanks you for help
Command: feeds
Or
Command: feeds
On feeds do
Endif
Thanks you for help
Re: Mqtt adafruit.io
Can you define the text to be sent by adafruit.io?
If so, please try to change it to "event,feeds"
Thank you for your reply.
I looked but I did not find how to change the sending of the adafruit
Can you setup the topic to which you want to send messages?
What have you configured to reach the ESP from Adafruit.io, at some point you must have configured the URL, or a MQTT Controller?
The reasoning behind my question for MQTT topics is that you can also use some of the MQTT topic as part of the command structure.
See the documentation: https://espeasy.readthedocs.io/en/lates ... #c005-page
configuration of my openhab mqtt:
Controller Subscribe: Username/feeds/#
Controller Publish: Username/feeds/%sysname%_%valname%
On adafruit i do not configure anythink
I changed Controller Subscribe with Username/feeds/cmd/#
But I lost the connection with adafruit and at the moment I can't find it
@TD-er,
Thanks you for your help.
I resolved the problème with the plugin Mqtt Import
Have a good day.
Have a good day.
Great!
Good to know you got it worked out.
Have fun with it and also a good day to you too.
Users browsing this forum: Google [Bot] and 1 guest
