In the "Log" I get the message "RTTTL : command not included in build".
This is probably due to my "custom build" that I make because I want to use the P141.
In PlatformIO.ini I included "default_envs = custom_ESP32_4M316k". I build with that.
In .\src\src\Custom.h I have included only those plugins and controllers that I need....(P005,P044,P049,P064,P141,C001)
What must I have to do to make the RTTTL command work?
Thanks in advance.
Re: RTTTL : command not included in build
You should also add:
Those defines starting with "FEATURE" have to be set to either 0 or 1.
#define FEATURE_RTTTL 1
OK, but where is the best place to put this line?
That can go in the Custom.h file, I assume you are already using. Maybe the available FEATURE flags should all be added to the Custom-sample.h file, for easier reference.
Thanks,
Rtttl command works fine again.
