telldus In-/Outdoor Thermo-/hygrometer (313159)
Naesstrom
#1 Post by Naesstrom » 26 Oct 2022, 20:57
I'm running RFlink 48 on a mega connected to Home-assistant and it's been working beautifully! Today I bought a telldus In-/Outdoor Thermo-/hygrometer (313159) to monitor my freezer temperature but it's showing the wrong values.
unnamed (4).png (982.32 KiB) Viewed 2605 times
The log shows the same problem:
2021-12-17 21:10:00 DEBUG (MainThread) [rflink.protocol] received data: 20;14;AlectoV3;ID=30c8
2021-12-17 21:10:00 DEBUG (MainThread) [rflink.protocol] received data: ;TEMP=80b3;BAT=OK;
2021-12-17 21:10:00 DEBUG (MainThread) [rflink.protocol] got packet: 20;14;AlectoV3;ID=30c8;TEMP=80b3;BAT=OK;
2021-12-17 21:10:00 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'alectov3', 'id': '30c8', 'temperature': -17.9, 'temperature_unit': '°C', 'battery': 'ok'}
2021-12-17 21:10:00 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'alectov3_30c8_temp', 'sensor': 'temperature', 'value': -17.9, 'unit': '°C'}
2021-12-17 21:10:00 DEBUG (MainThread) [homeassistant.components.rflink] event of type sensor: {'id': 'alectov3_30c8_temp', 'sensor': 'temperature', 'value': -17.9, 'unit': '°C'}
2021-12-17 21:10:00 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['sensor.alectov3_30c8_temp']
2021-12-17 21:10:00 DEBUG (MainThread) [homeassistant.components.rflink] passing event to sensor.alectov3_30c8_temp
After some searching I found another thread on the home-assistant forum (https://community.home-assistant.io/t/t ... ink/239318) where someone had the exact same problem. The solution seemed to be:
I contacted the support and it´s a problem with Alecto devices using the same pulse as tellstick but coding temperature in a different way. The guys where wery helpful and provided me with a solution
So I would love to get the same solution but I've tried emailing the creator since 2021 so I'm posting here now, does anyone have the firmware that works with alecto devices?
Is it possible to flash the new firmware from the Pi it's connected to or do I need to hook it up to my PC?
kalj
Re: telldus In-/Outdoor Thermo-/hygrometer (313159)
#2 Post by kalj » 26 Mar 2023, 12:25
I too am having this problem with these sensors, and I am too looking for a firmware with the fix.
I noticed that the changelog entry from 6-1-2022 (https://www.rflink.nl/changelog.php), mentions a fix for this issue. I would very much appreciate to get access to this fixed firmware version!
Naesstrom
#3 Post by Naesstrom » 31 Mar 2023, 19:09
kalj wrote: 26 Mar 2023, 12:25 I too am having this problem with these sensors, and I am too looking for a firmware with the fix.
yeah I think thats the solution that I linked to in the OP to, question is how to get hold of the new firmware?!
