I bought an ESP32-CAM. It works fine. I use the program in the Arduino IDE. Is there a possibility to use the cam with ESP Easy?
Thanks and best regards!
ESP32-CAM using with ESP Easy
Re: ESP32-CAM using with ESP Easy
This has been requested before:
- Forum: viewtopic.php?p=47010
- Issue tracker: https://github.com/letscontrolit/ESPEasy/issues/3272
It's not on the shortlist for new plugins, though, as the code needed to handle the camera properly requires most of the available code-space, and won't allow much of ESPEasy next to it. And also, the data streams in ESPEasy are not (yet) fit for the amount of streaming data, that is to be expected from a camera.
In the forum thread mentioned above are some alternative projects to enable the use of the camera.
Users browsing this forum: Ahrefs [Bot] and 48 guests
