Dear developers...
Is there perhaps a option that the a UV sensor is going to work with the ESPeasy ....
Great option for my terrarium..
UV
Re: UV
@Dylantje
The ML8511 and GUVA-S12SD devices from Adafruit (or direct from China) generate a DC-Voltage which can be interfaced to the ADC-interface of the ESP8266:
support by ESPEasy is simply as an analogue signal at the ADC-port.
If you want UV-measurement digitally by means of the I2C-interface, the SI1145-breakout or the VEML6070-breakout are candidates.
For SI1145 an ino-file is available at this forum. For VEML6070 I did not (yet) see any support.
This url https://learn.adafruit.com/adafruit-vem ... r-breakout summarizes the differences between the various options.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
