[solved]mqtt button ?
bledad
#1 Post by bledad » 27 Jul 2022, 16:17
hello,
before I start, I would like to know if it is possible
i've mqtt server , the channel is : actions_bouton
i publish : sonnette#on , sonnette#off
from the espeasy side I would like
example :
On Clock#Time=All,**:** Do
  if mqtt#sonnette = on
   if  %syssec_d% > 28800 and %syssec_d% < 72000 //de 7h a 20h
     gpio,13,0
     gpio,13,1
  if mqtt#sonnette = off
     gpio,13,1
i,ve 8 button , its for each button
but now, I don't know how to do it
Re: mqtt button ?
#2 Post by Ath » 27 Jul 2022, 16:26
This part is not going to work:
(Same for the one with 'off' )
as ESPEasy doesn't yet support string handling like that.
Depending on the build you use (Custom and MAX, AFAIR), the MQTT Import plugin can be configured to translate an on or off state to a numeric value (1 and 0 seem most appropriate), and stored in a Dummy task value.
Then that dummy can be checked:
  if [Dummy#Button1]=1 // Expects a `Generic - Dummy` task, with value Button1
     gpio,13,0
     gpio,13,1
  else // It must be off
     gpio,13,1
bledad
Re: mqtt button ?
#3 Post by bledad » 27 Jul 2022, 17:16
ok ,
i use "ESP_Easy_mega_20220616_normal_ESP8266_4M1M"
i think have a probleme , because some buttons has three state ( on, off , auto)
I need to rename the mqtt states?
ex : on > 1 , off > 2 , auto >3
and after for link mqtt with dummy in rules ?
bledad
Re: mqtt button ?
#4 Post by bledad » 28 Jul 2022, 13:56
ok , iv'e renamed the mqtt states by value
now , in my mqtt server i have
channel : actions_bouton
topics : sonnette
if i put in rules :
Publish sonnette_status auto
mqtt server not receive
i do :
in controllers : openhab(mqtt) enable with ip , Controller Subscribe : actions_bouton/# and Controller Publish: actions_bouton/#
in Devices : MQTT Import enable with MQTT Topic 1: sonnette
what is the format mqtt for espeasy ?
or how to transcribe
mosquitto_pub -h 192.168.1.51 -t 'actions_bouton' -m 'sonnette_status#1'
in espeasy ??
please
thank
Users browsing this forum: Bing [Bot] and 35 guests
