System event that is only triggered by coldboot
chromo23
#1 Post by chromo23 » 22 Jul 2022, 21:58
Is there a way to determine whenever there is a wake from sleep or a coldboot?
It seems that system#wake and system#boot are triggered either way.
I wanted to prevent a deepsleep via rules by setting a variable only after a coldboot instead of using a pin.
I thought about something like this:
On System#Wake Do
	Let,1,0
On Rules#Timer=1 Do
	If [var#1]=1
		DeepSleep,60
	Else
		TimerSet,1,30
		Let,3,1
	Endif
chromo23
Re: System event that is only triggered by coldboot
#2 Post by chromo23 » 22 Jul 2022, 22:02
On System#Wake Do
When i look at this event it seems counterintuitive to use it but it is triggered before System#Boot right?
#3 Post by TD-er » 22 Jul 2022, 22:06
You can add a dummy task and set a value in that dummy using taskvalueset.
Since it is a task value, it will be kept in RTC memory and restored on a warm boot.
chromo23
#4 Post by chromo23 » 22 Jul 2022, 22:16
Of course...had a knot in my head... :roll:
Working code:
On Rules#Timer=1 do
	If [boot#isboot]=1
		DeepSleep,30
	Else
		TimerSet,1,30
		TaskValueSet,boot,1,1
	Endif
#5 Post by Ath » 22 Jul 2022, 23:28
Setting var#1 to zero on wake isn't any helpful, as it will also be 0 on system#boot/cold boot :shock: ;)
chromo23
#6 Post by chromo23 » 23 Jul 2022, 00:02
I knooooow but i didn´t want to take any chances to mess up with deepsleep and i somehow was afraid, that if i don´t declare it, i will be in a undefined state :shock:
(It´s a kind of hardwarethinking where a pin behaves unpredictable when you don’t pull it up or down)...
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 34 guests
