Suggestion to improve the MPU6050 driver
mackowiakp
#1 Post by mackowiakp » 02 May 2022, 04:53
At the moment, MPU6050 motion detection works in such a way that the statement that motion has occurred is based on the finding that activation has occurred in ALL enabled axes.
In the case of a washing machine, it turns out that it is better to check that the stimulation occurred in ANY axis.
I wrote a script to implement this using rules. It works much better than the original motion detection included in the driver.
My suggestion is that there should be, for example, a checkbox toggling between ANY/ALL axes.
Below is a proposition of the driver part _P045_MPU6050.ino for a function that executes ANY instead of ALL axes.
 boolean thresexceed = false;  // changed from true to false
            uint8_t    count       = 0; // Counter to check if not all thresholdvalues are set to 0 or disabled
            for (uint8_t i = 0; i < 3; i++)
              // for each axis:
              if (PCONFIG(i + 2) != 0) { // not disabled, check threshold
                if (P045_data->_axis[i][2] > PCONFIG(i + 2)) { thresexceed = true; } // changed < to > and false to true
              } else { count++; }        // If disabled count + 1
	    // the line below is not necessary now
            if (count == 3) { thresexceed = false; } // If we counted to three, all three axis are disabled.
            // If ANY (not all) enabled thresholds are exceeded the increase the counter
            if (thresexceed) { PCONFIG_LONG(0)++; }
mackowiakp
Re: Suggestion to improve the MPU6050 driver
#3 Post by mackowiakp » 02 May 2022, 11:20
THX
#4 Post by Ath » 06 May 2022, 08:45
I have created a pull request #4042 with the intention to implement this request. You can download from the Github Actions build for testing. Please report your findings ;)
mackowiakp
#5 Post by mackowiakp » 06 May 2022, 11:41
OK. Will try next weekend. Now I am in a humanitarian convoy to the hospital in Winnica (Vinnitsa)/Ukraine.
Hope will be back alive Thursday evening.
#6 Post by Ath » 06 May 2022, 14:23
mackowiakp wrote: 06 May 2022, 11:41 Now I am in a humanitarian convoy to the hospital in Winnica (Vinnitsa)/Ukraine.
Good luck :!:
mackowiakp
#7 Post by mackowiakp » 06 May 2022, 15:33
We say "You are shooting or they are shooting at you - what's the difference? The same bang" :)
#8 Post by Ath » 05 Jul 2022, 12:59
Any update on testing this request (and possibly your 'trip' to Ukraine :o)?
mackowiakp
#9 Post by mackowiakp » 05 Jul 2022, 16:32
I was 3 times in Ukraine so I have not time to test FW. Will do it ASAP.
sobolkz
#10 Post by sobolkz » 05 Jul 2022, 20:33
mackowiakp wrote: 05 Jul 2022, 16:32 I was 3 times in Ukraine so I have not time to test FW. Will do it ASAP.
So, I'm from Kazakhstan, I'm looking about loosing Ukrainian independent, what about topic state?
Let`s don`t politise this forum.
Users browsing this forum: Ahrefs [Bot] and 129 guests
