http://ams.com/eng/Products/Environment ... iAQ-core-C
Anyone using this device to measure VOC/CO2?
AMS iAQ Core support? VOC/CO2
Re: AMS iAQ Core support? VOC/CO2
I am using this one (has basically the same sensor inside):
http://ams.com/eng/Products/Environment ... ensors/iAM
Measurements are highly dependent on temperature/humidity/aging!
Reproducable results are impossible!
GOOD LUCK compensatin it
If you have extreme situations like smoke in a room or a used toilet, the sensor MIGHT give you a short term realiable signalling; but do you wanna correct the threshold every month again? -NO! So don't waste your money and time with it.
I can absolutely NOT recommend these sensors.
Then the SenseAir S8 could be an option (75 euros)
http://www.senseair.com/products/oem-mo ... nseair-s8/
http://www.sensor-test.de/ausstellerber ... mBH_13.pdf
https://www.m.nu/co2matare-fran-senseair-p-1440.html webshop in Sweden
Or we wait till Q1 2017 for the Bosche BME680 VOC sensor: http://www.uradmonitor.com/bosch-bme680/
I also find this one: MICS-VZ-89F http://www.sgxsensortech.com/content/up ... -rev-6.pdf
https://sgx.cdistore.com/ProductDetail/ ... xSLkaiLShc
https://github.com/radhoo/mics_vz_89t
http://www.pocketmagic.net/mics-vz-89-a ... ty-sensor/
Maybe an alternative?
Users browsing this forum: Google [Bot] and 2 guests
