Devices goes offline
Moderators: grovkillen, Stuntteam, TD-er, enesbcs
Hello, first of all cool project. I use one to controlling my water tank. I have some troubles: If have difrent devices: Simple OLEd, Extra IO PCF8574, Environment BH1750 Lux, Distance HC SR04, Generic Input, Serial Communication. The biggest issue is that the Generic Input stop working after few hours. The Input doesn´t change anymore. (No notification at MQTT and no change in web application) I had to click manually Run in the Web appliction and after that it works for the next hours!? Also when I use an output of the PCF8574 the serial device stops working. Why are the interacting ? I am running at 2.1.339 I can´t find information about if it is the last version ? I see that there a lot of old topics, is there no more development in the RPI Easy ? thanks Christoph
Re: Devices goes offline
Nobody an idea ?Rosenberg wrote: ↑12 May 2022, 17:58 Hello, first of all cool project. I use one to controlling my water tank. I have some troubles: If have difrent devices: Simple OLEd, Extra IO PCF8574, Environment BH1750 Lux, Distance HC SR04, Generic Input, Serial Communication. The biggest issue is that the Generic Input stop working after few hours. The Input doesn´t change anymore. (No notification at MQTT and no change in web application) I had to click manually Run in the Web appliction and after that it works for the next hours!? Also when I use an output of the PCF8574 the serial device stops working. Why are the interacting ? I am running at 2.1.339 I can´t find information about if it is the last version ? I see that there a lot of old topics, is there no more development in the RPI Easy ? thanks Christoph
You have installed all updates for your RPi? As I've seen all kind of issues, with other s/w too, if the OS isn't updated regularly.
I guess the Generic Input is the "Input - Switch Device/Generic GPIO" plugin.
As you did not provide any detail i recommend enable "Force 10/sec periodic checking of pin", and can also play with debounce time, as it can yield quick changes if setted too large...
I hope the correspondent GPIO is setted up as input, as there are another "Output helper" plugin for output management.
It can also be a lot of other issues depending on your actual setup, as used GPIO's, I2C, pullup resistors, operating system, python versions, other running programs in the background, etc... if this pin also used or tried to use by other app OR device OR the operating system themself the pin setup and ownership may also change, which stops the RPIEasy loop asking this plugin.
