Hellow!
Unable to get text data from MQTT topic
Subscribe %sysname%/#
It is necessary that the text from a topic appeared in a variable.
Generic - MQTT Import only works with numeric content (.
Please help with an example with syntax
ESP Easy How Subscribe MQTT Text value?
Re: ESP Easy How Subscribe MQTT Text value?
ESPEasy doesn't (yet) support handling string values in variables.
When using the MQTT Import plugin with the extensions available (may require installing a Normal build or creating a personal Custom build with P037 included) you can
a) Have events generated per topic, where the value is available in the rule via argument %eventvalue1%
b) Use the Mapping feature to convert known alphanumeric values to numeric equivalents (like "on" to 1 and "off" to 0, etc.)
Users browsing this forum: Ahrefs [Bot] and 34 guests
