RFLINK - TFA Dostmann 30.3240.10 : Inclusion dans Domoticz
French support forum, post can be done in French, answers will either be in French or in English.
Moderators: rtenklooster, Voyager, BertB, Stuntteam, Deennoo
zozo01170
#1 Post by zozo01170 » 19 Jun 2020, 15:31
Bonjour,
J'ai un thermomètre connecté de la marque TFA Dostmann référence 30.3240.10. J'arrive sans problème à l'ajouter à mes dispositif dans Domoticz mais il me remonte une température farfelue... A l'intérieur, alors qu'il fait 21.5°C, le thermomètre indique -12.8°C. De plus, après une nuit, la température ne s'est pas actualisée dans Domoticz, le dernier contact date de la veille au soir.
J'ai également testé avec le tool RFLink Loader. Avec RFDebug sur ON, il y a une remontée d'information toutes les minutes :
20;05;RFDEBUG=ON;
20;06;DEBUG;Pulses=74;Pulses(uSec)=60,450,540,1710,480,3720,510,1770,480,1770,450,1770,480,1860,480,3690,480,3690,480,3690,480,3780,480,1770,450,1800,480,1800,450,1860,450,1830,420,1800,450,1800,450,1860,450,3720,450,3690,450,3690,450,3750,450,3720,450,1800,450,1800,450,3780,450,1830,450,1800,420,1830,420,1860,450,1830,450,1800,450,1800,420,1860,450,900,540,6990;
20;07;DEBUG;Pulses=42;Pulses(uSec)=480,1740,390,1740,390,1800,420,3720,450,3720,450,3720,420,3810,450,3750,420,1830,420,1830,420,3810,450,1830,450,1800,450,1800,420,1920,450,1830,420,1830,420,1830,420,1890,420,900,540,6990;
20;08;DEBUG;Pulses=58;Pulses(uSec)=480,3540,420,3510,420,3810,450,1830,450,1800,420,1830,420,1890,450,1830,420,1830,420,1830,420,1890,450,3720,450,3720,450,3720,420,3810,450,3750,420,1830,420,1800,450,3810,450,1830,450,1800,420,1830,420,1890,450,1830,420,1830,420,1830,420,1920,420,900,540,6990;
20;09;DEBUG;Pulses=52;Pulses(uSec)=510,1740,390,1740,390,1740,390,1890,420,1830,420,1830,420,1830,420,1890,420,3690,420,3750,450,3720,420,3810,450,3750,450,1800,450,1800,450,3810,450,1830,420,1830,420,1800,450,1890,420,1770,420,1830,450,1830,420,1890,420,1020,510,6990;
20;0A;DEBUG;Pulses=54;Pulses(uSec)=480,3600,420,1740,390,1800,420,1830,420,1920,420,1860,390,1860,420,1860,420,1890,390,3690,420,3750,420,3720,420,3810,420,3750,420,1830,420,1830,420,3780,420,1770,420,1830,420,1830,420,1890,420,1860,420,1830,420,1830,420,1890,420,930,510,6990;
20;0B;DEBUG;Pulses=52;Pulses(uSec)=480,1770,390,1740,420,1830,420,1890,420,1860,420,1830,420,1830,420,1920,420,3750,420,3750,390,3750,420,3810,390,3690,390,1860,390,1860,390,3840,420,1860,420,1830,420,1830,420,1920,420,1860,420,1830,390,1860,390,1920,390,930,510,6990;
20;0C;DEBUG;Pulses=54;Pulses(uSec)=480,3630,390,1740,360,1830,390,1860,390,1920,420,1860,390,1860,390,1860,390,1920,390,3720,390,3750,420,3750,390,3810,420,3750,420,1830,420,1830,420,3810,420,1860,390,1860,390,1830,420,1890,390,1800,420,1830,420,1830,420,1920,390,450,390,6990;
Quelqu'un a-t-il déjà couplé ce genre de thermomètre à Domoticz ?
Merci pour votre aide et toute bonne journée.
Bien cordialement.
Ludovic
jjlf
Re: RFLINK - TFA Dostmann 30.3240.10 : Inclusion dans Domoticz
#2 Post by jjlf » 25 May 2022, 20:16
Bonjour, as tu résolu ton problème ? J'ai le même produit mais je n'arrive même pas à l'inclure dans domoticz.
J'utilise RFLINK R48.
Merci d'avance
Hello, did you solve your problem ?
I can't get this device included in domoticz with RFLINK R48.
-JJLF-
