Hey all. I'm having some trouble adding a switch that has "on" and "off" to it to my home assistant
I have RF link speaking to home assistant but I'm not too sure how to add the switch as a device to it
The info I got from the switch when using rflink loader is as follows
20;05;TriState;ID=820aa0;SWITCH=10;CMD=OFF;
20;06;AB400D;ID=4e;SWITCH=7;CMD=ON;
Any help would be appreciated
Home Assistant Set up
Re: Home Assistant Set up
make sure you have set the autoadd option = on in config.yaml
when new device is found (name depends op protocol/manaufacturer) add new switch in config.yaml like this:
- platform: rflink
automatic_add: true
devices:
#remote KAKU APA3-1500R
newkaku_009fdd7e_0:
name: groep control APA3
newkaku_009fdd7e_1:
newkaku_009fdd7e_2:
newkaku_009fdd7e_3:
- platform: rflink
automatic_add: true
devices:
newkaku_009fdd7e_0:
newkaku_009fdd7e_1:
newkaku_009fdd7e_2:
newkaku_009fdd7e_3:
just another DIY tinkerer
