TM1637 7seg LED Display
Hello. I am trying to connect 2 displays with 4 digits on TM1637 each to their DIO and CLK pins. Can these displays be controlled individually?
Re: TM1637 7seg LED Display
You need to add the taskname in square brackets in front of the command.
here an example of setting the brightness of two displays where the tasks are called display1 and display2:
[display1].7db,10
[display2].7db,10
Indexes 1 and 2 are tied to device numbers on the Devices tab?
How and when will displays learn their names 1 and 2? When configuring the LED, it is not possible to assign a name.
The name you have assigned to the task:
(This unit does not have displays attached, it is just an illustration of the taskname mentioned)
The name must be unique per task, that is a requirement to be able to select the correct task, of course.
Thank you. As I did not guess ... It's elementary.
Your original question is explained in this documentation page
Users browsing this forum: Ahrefs [Bot] and 0 guests
