TM1637 7seg LED Display
sartam
#1 Post by sartam » 18 Apr 2022, 20:11
Hello. I am trying to connect 2 displays with 4 digits on TM1637 each to their DIO and CLK pins. Can these displays be controlled individually?
chromo23
Re: TM1637 7seg LED Display
#2 Post by chromo23 » 18 Apr 2022, 22:24
You need to add the taskname in square brackets in front of the command.
here an example of setting the brightness of two displays where the tasks are called display1 and display2:
 [display1].7db,10
 [display2].7db,10
sartam
#3 Post by sartam » 19 Apr 2022, 07:48
Indexes 1 and 2 are tied to device numbers on the Devices tab?
#4 Post by Ath » 19 Apr 2022, 08:33
No, they are the names you assigned to the Tasks.
sartam
#5 Post by sartam » 19 Apr 2022, 10:02
How and when will displays learn their names 1 and 2? When configuring the LED, it is not possible to assign a name.
#6 Post by Ath » 19 Apr 2022, 10:36
The name you have assigned to the task:
Screenshot - 19-04-2022 , 10_32_06.png (31.72 KiB) Viewed 5318 times
(This unit does not have displays attached, it is just an illustration of the taskname mentioned)
The name must be unique per task, that is a requirement to be able to select the correct task, of course.
sartam
#7 Post by sartam » 19 Apr 2022, 11:23
Thank you. As I did not guess ... It's elementary.
#8 Post by Ath » 19 Apr 2022, 14:17
Your original question is explained in this documentation page
