Question about floating-point numbers
chromo23
#1 Post by chromo23 » 13 Apr 2022, 10:53
just wanted to ask if this is a bug or normal behaviour with floating-point precision?
taskvalueset,4,1,1023.1220
taskvalueset,4,1,1024.1220
taskvalueset,4,1,1023.1070
taskvalueset,4,1,1024.1070
As you can see the last decimal changes when the number in front of the decimals gets bigger than 1023....
(it does not happen with every decimal number but with some)
Re: Question about floating-point numbers
#2 Post by TD-er » 13 Apr 2022, 12:30
Yep, that's a floating point issue.
A float does have 23 bits to store the decimals. See: https://en.wikipedia.org/wiki/Single-pr ... :_binary32
The task values use float values.
The variables used in rules, use double values, exactly for this reason.
However the variables will be lost after reboot and the task values will be restored from RTC memory after a reboot. (as long as the unit remains powered)
Storing the same decimals, without a dot (thus as large integer) will also fail the same way.
Typical use case which has come across this forum a few times, is to store the unixtime in seconds in a dummy.
chromo23
#3 Post by chromo23 » 13 Apr 2022, 12:51
TD-er wrote: 13 Apr 2022, 12:30 Storing the same decimals, without a dot (thus as large integer) will also fail the same way.
Maybe i missunderstand that but:
This seems to work
taskvalueset,4,1,10231070
taskvalueset,4,1,10241070
#4 Post by TD-er » 13 Apr 2022, 12:59
10241070 is in binary: 1001 1100 0100 0100 0010 1110
That's exactly 23 bits which are significant and a trailing zero.
So in theory, adding 1 to the value may cause a rounding error.
The largest integer you can store without loosing a significant bit is 8388608
8388609 may cause a rounding error.
Such rounding errors may occur sooner on floating point values as some values in base 10 notation have an infinite repeating pattern in base 2.
From memory, 0.2 was such a number.
But in my code to format numerical values I try to prevent strange rounding errors so a user may not see them.
chromo23
#5 Post by chromo23 » 13 Apr 2022, 13:07
I understand (i guess ;) ).
Thank you for the explanation!
Users browsing this forum: Ahrefs [Bot] and 28 guests
