Hi all. not so long ago I became interested in the ESP Easy firmware. And after some thought and testing the firmware on the modules, I came to the decision to make a printed circuit board for the ESP processor. Under a certain body, with some more goodies. The result was a project implemented in the Easy EDA environment. divorced on the board: ESP 8266, DS3231, memory chip AT24C02M/TR, battery, output optocoupler, input optocoupler, separate connector for DS18B20, for LCD2004. buttons reset, boot 2 types are provided: straight and "sideways". Open source project. and is presented according to the principle: "I am an artist, I see it this way." If you have questions, ask.
Button https://aliexpress.ru/item/100500132122 ... a396R1qWLF
Bodi https://aliexpress.ru/item/100500249552 ... a396R1qWLF
Holder batteri https://aliexpress.ru/item/32999232652. ... a396R1qWLF
The rest of the components are pretty standard and not hard to find on your own.
project https://oshwlab.com/sartam/esp_easy
Sorry for my english.
I plan to make a similar board for ESP32. If there is interest from the community, I will gladly share the project.
PCB ESP Easy
Re: PCB ESP Easy
Looks nice
You also have the EEPROM included, but it is not (yet) supported in ESPEasy.
Do you have plans to add your own implementation?
Re: PCB ESP Easy
No. Not yet. I am not so strong in programming to create a plug-in for a memory chip . It's just that the board can be used not only for ESP Easy firmware, but also for other projects.
Re: PCB ESP Easy
Maybe a respected TD-er, if he suddenly has time, and he will devote it to us and write EEPROM support?
Users browsing this forum: Bing [Bot] and 30 guests
