Plugin_153 MAX44009, anyone got it working ?
I have a GY-49 module , it has a MAX44009 lux sensor. I found playground plugin_0153 and gave it a try.
So compiled ESPEasy 148 with plugin153. But the sensor does not show_up in the device list.
Did someone succesfully use this sensor in ESPEasy?
Re: Plugin_153 MAX44009, anyone got it working ?
Please make sure that the plugin is not #def as testing or development.
@grovkillen
tnx for the suggestion.
I removed at beginning the line:
#ifdef PLUGIN_BUILD_TESTING
and on the end of plugin the line
#endif
Apparently the plugin was ignored at first, now I get some compile errors like:
I will see if I can fix the errors.
#endif
_P153_MAX44009.ino: In function 'boolean Plugin_153(byte, EventStruct*, String&)':
_P153_MAX44009:130: error: 'addFormSelector' was not declared in this scope
_P153_MAX44009:158: error: 'getFormItemInt' was not declared in this scope
Since a few days plugin 153 basically works for me in ESPEasy148.
To get rid of these 2 compile errors:
I had to comment out these 6 lines
wihout these lines the plugin basically works, gives me the lux value with 22bit definition, much better than a BH1750 sensor.
Apparently because I removed the 6 lines from the WEBFORM LOAD/SAVE part, the "Optional Settings" form in the device tab does not function anymore. I cannot use the "Formula Lux" because what is put there is not processed or saved.
Which is sad, because I would like to put there something like %value%^0.1 so that the values communicated to my RaspberryPi based Domoticz server are displayed logarithmic, just like the eye is logarithmic.
I am not used to programming with plugins, so I am not sure how to fix this.
Any clues would be appriciated a lot.
In case PLUGIN_WEBFORM_LOAD
addFormSelector(string, F("Mode"), F("plugin_153_mode"), 3, options, optionValues, choice_mode)
addFormSelector(string, F("Current Division Ratio"), F("plugin_153_divide"), 2, options, optionValues, choice_division);
addFormSelector(string, F("Integration Time"), F("plugin_153_time"), 8, options, optionValues, choice_time);
and in case PLUGIN_WEBFORM_SAVE:
Settings.TaskDevicePluginConfig[event->TaskIndex][0] = getFormItemInt(F("plugin_153_mode"));
Settings.TaskDevicePluginConfig[event->TaskIndex][1] = getFormItemInt(F("plugin_153_divide"));
Settings.TaskDevicePluginConfig[event->TaskIndex][2] = getFormItemInt(F("plugin_153_time"));
Why stick to the build 148, when you can also use the 2.0 dev series, or even the Mega branch?
I tested the MAX44009 plugin in dev2.0 but ...
No difference, same 6 errors as with the old version 148.
There are some omissions somewhere in the sketch or the plugin. I think i must declare the string variables somewhere somehow.
I was hoping someone who has written a plugin before could see the solution and explain what needs to be changed/added.
Tested dev 2.0 again with this MAX44009 plugin, but now with the latest sources from github, also latest libraries.
The compile errors disappeared![Razz :P](./images/smilies/icon_razz.gif)
But . . . . . . . still cannot edit the formula field, everything entered there disappears after clicking "submit" , so it is not saved.
Finally solved it.
The solution was in this post viewtopic.php?f=6&t=3689&p=20157&hilit=formula#p20157
The problem was not in the software nor in the plugin. It was the ESP8266 2.4.0.rc2 core.
When I used the 2.4.0.rc1 core I could save my optional settings agian.![Razz :P](./images/smilies/icon_razz.gif)
Yeah, it took some time to find it out.![Bedroeft :(](./images/smilies/icon_e_sad.gif)
Any idea, when Plugin #153 / support for MAX44009 will be added to the release?
Hi everyone! Sorry to revamp an old thread, but this seems to be the only one concerning MAX44009 (plugin153).
I have updated firmware on my ESP8266 and found that this plugin is not yet there (ESPEasy Mega dev).
Has anybody any new about this? I can't find it in offcial plugin list and seems just to be vanished.
Thanks for any help.
Is part of the playground
https://github.com/letscontrolit/ESPEas ... Playground
So you have to add it to your own compilation.
You could request to add it to the mega here:
https://github.com/letscontrolit/ESPEas ... +is%3Aopen
This will help: http://ko-fi.com/GrovkillenTDer
Hallo
vielleicht gibt es ja schon eine Lösung und der Post ist ja auch schon sehr alt, aber ich hatte das gleiche Problem und habe das Plugin compiliert bekommen.
so sieht es jetzt aus:
Gruß rippi
#include "_Plugin_Helper.h"
#ifdef USES_P153
//############################### Plugin 153: MAX44009 I2C 0x4A #######################################
// based on :
// 1) https://github.com/RobTillaart/Arduino/tree/master/libraries/Max44009
// 2) https://github.com/dantudose/MAX44009/blob/master/MAX44009.cpp
// written by https://github.com/apszowski
#define PLUGIN_153
#define PLUGIN_ID_153 153
#define PLUGIN_NAME_153 "Light/Lux - MAX44009 (GY-49)"
#define PLUGIN_VALUENAME1_153 "Lux"
boolean Plugin_153_init = true;
enum {
//I2C address
MAX44009_I2C_ADDR = 0x4A,
// CONFIGURATION
MAX44009_REGISTER_CONFIGURATION = 0x02,
MAX44009_CFG_MANUAL = 0x40,
MAX44009_CFG_CONTINUOUS = 0x80,
//LUX READING
MAX44009_REGISTER_LUX_HIGH = 0x03,
MAX44009_REGISTER_LUX_LOW = 0x04,
uint16_t Plugin_153_readRegister(uint8_t reg) {
uint16_t ret;
Wire.beginTransmission(MAX44009_I2C_ADDR);
Wire.write(reg);
Wire.endTransmission();
Wire.requestFrom(MAX44009_I2C_ADDR,1);
ret = Wire.read();
return ret;
void Plugin_153_writeRegister(uint8_t reg, uint8_t value){
Wire.write(reg);
Wire.write(value);
float Plugin_153_readLux(void)
uint8_t luxHigh = Plugin_153_readRegister(MAX44009_REGISTER_LUX_HIGH);
uint8_t luxLow = Plugin_153_readRegister(MAX44009_REGISTER_LUX_LOW);
uint8_t e = (luxHigh & 0xF0) >> 4;
uint8_t m = (luxHigh & 0x0F) << 4 | luxLow;
float lux = pow(2,e) * m * 0.045;
return lux;
void Plugin_153_setModeAutomatic(void)
uint8_t config = Plugin_153_readRegister(MAX44009_REGISTER_CONFIGURATION);
config &= ~MAX44009_CFG_CONTINUOUS; // off
config &= ~MAX44009_CFG_MANUAL; // off
Plugin_153_writeRegister(MAX44009_REGISTER_CONFIGURATION, config);
void Plugin_153_setModeContinuous(void)
config |= MAX44009_CFG_CONTINUOUS; // on
void Plugin_153_setModeManual(uint8_t CDR, uint8_t TIM)
config |= MAX44009_CFG_MANUAL; // on
config &= 0xF0; // clear CDR & TIM bits
config |= CDR << 3 | TIM;
boolean Plugin_153(byte function, struct EventStruct *event, String& string)
boolean success = false;
switch (function)
case PLUGIN_DEVICE_ADD:
Device[++deviceCount].Number = PLUGIN_ID_153;
Device[deviceCount].Type = DEVICE_TYPE_I2C;
Device[deviceCount].VType = Sensor_VType::SENSOR_TYPE_SINGLE;
Device[deviceCount].FormulaOption = true;
Device[deviceCount].ValueCount = 1;
Device[deviceCount].GlobalSyncOption = true;
case PLUGIN_GET_DEVICENAME:
string = F(PLUGIN_NAME_153);
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_153));
case PLUGIN_WEBFORM_LOAD:
byte choice_mode = Settings.TaskDevicePluginConfig[event->TaskIndex][0];
String options[8];
int optionValues[8];
options[0] = F("Automatic");
optionValues[0] = 0;
options[1] = F("Continuous");
optionValues[1] = 1;
options[2] = F("Manual");
optionValues[2] = 2;
addFormSelector(F("Mode"), F("plugin_153_mode"), 3, options, optionValues, choice_mode);
if( choice_mode != 0)
byte choice_division = Settings.TaskDevicePluginConfig[event->TaskIndex][1];
options[0] = F("Not divided");
options[1] = F("Divided 1/8");
addFormSelector(F("Current Division Ratio"), F("plugin_153_divide"), 2, options, optionValues, choice_division);
byte choice_time = Settings.TaskDevicePluginConfig[event->TaskIndex][2];
float integration_time = 800;
for( uint8_t i = 0 ; i <= 7 ; i++)
options[i] = integration_time;
options[i] += F(" ms");
optionValues[i] = i;
integration_time = integration_time/2.0;
addFormSelector(F("Integration Time"), F("plugin_153_time"), 8, options, optionValues, choice_time);
success = true;
Plugin_153_init = false;
success = true;
case PLUGIN_INIT:
uint8_t mode = Settings.TaskDevicePluginConfig[event->TaskIndex][0];
uint8_t divide = Settings.TaskDevicePluginConfig[event->TaskIndex][1];
uint8_t tim = Settings.TaskDevicePluginConfig[event->TaskIndex][2];
String log = F("MAX44009 :\rINIT MODE = ");
if( mode == 0)
Plugin_153_setModeAutomatic();
log += F("Automatic");
else if ( mode == 1)
Plugin_153_setModeContinuous();
log += F("Continuous");
Plugin_153_setModeManual(divide,tim);
log += F("Manual , CDR = ");
log += divide;
log += F(", Integration Time = ");
log += tim;
addLog(LOG_LEVEL_INFO,log);
success = true;
case PLUGIN_READ:
UserVar[event->BaseVarIndex] = (float) Plugin_153_readLux();
String log = F("MAX44009 : Ambient Light: ");
log += UserVar[event->BaseVarIndex];
success = true;
return success;
#endif
- ESP_Easy_mega_20220317_custom_ESP8266_4M1M.bin.gz
- (594.36 KiB) Downloaded 207 times
Hi rippi,
You are welcome to adopt the plugin for use in the regular ESPEasy builds, the procedure to obtain the next available plugin ID is described here on the Github repository (we like those plugin ID's sequentially).
In the documentation pages of ESPEasy, on ReadTheDocs, a description is available on how the development of a plugin (or adaptation of a PluginPlayground plugin) is done. You can find that page here. This is focused on development using VSCode & PlatformIO, as that's our preferred IDE, currently, On the same page, a few paragraphs up, you can find a guide on how to configure VSCode with PlatformIO, but you can in fact use any IDE/Editor you prefer, the basic principles are still the same.
NB: This plugin is not really up to date with the current standards for development with ESPEasy, but you will get some guidance during the pull request process![Knipoog ;)](./images/smilies/icon_e_wink.gif)
