I tested all three firmwares *8285* as well as a 1M for 8266 of the Release mega-20190903.
Flashing always was successful as was connecting to setup page (192.168.4.1).
I could setup router details and connect to it.
When changing setup however a write error occurs (Tools->Advanced->NTP-> e.g.):
SaveToFile: config.dat ERROR, Cannot save to file
Sometimes with a line number, sometimes without.
Changing and saving the Rules doesn't end in an error.
It's an ESP8285.
When unplugging and restarting, the connection to my WiFi is lost and I have to restart using setup IP (192.168.4.1).
As ESP_Easy_mega-20190903_minimal_core_242_ESP8285_1M_OTA.bin is less than 600kB I'm not sure if it's really related to lack of memory.
No OTA flash but cabled to an FTDI programmer for flashing using ESP Easy Flasher under Windows 10.
I flashed the blank_1MB and retried using ESP_Easy_mega-20190903_hard_core_252_other_POW_ESP8285_1M.
Already at setup @192.168.4.1: Warning: Connected via AP + SaveToFile: config.dat ERROR, Cannot save to file -
I flashed the blank_1MB and retried using ESP_Easy_mega-20190903_hard_other_POW_ESP8285_1M.
Already at setup @192.168.4.1: Warning: Connected via AP + FS: Error while reading/writing config.dat in 774 -
I flashed the blank_1MB and retried using ESP_Easy_mega-20190903_minimal_core_242_ESP8285_1M_OTA.
same as before.
Chip:
Storage
Flash Chip ID: Vendor: 0x51 Device: 0x4014
Flash Chip Real Size: 1024 kB
Flash IDE Size: 1024 kB
Flash IDE Speed: 40 MHz
Flash IDE Mode: DOUT
Flash Writes: 3 daily / 3 boot
Sketch Size: 704 kB (168 kB free)
SPIFFS Size: 110 kB (28 kB free)
Page size: 256
Block size: 4096
Number of blocks: 27
Maximum open files: 5
Maximum path length: 32
