recover password for login *narf*
dna
#1 Post by dna » 12 Dec 2021, 16:37
Hi there,
I installed ESPeasy on a ESP8266 some weeks ago, all fine, great tool :D
But now, I can't remember the password (so dumb).
Is there any way to recover or reset it?
I have direct access to it, so I can use USB to connect.
Is there a way to access security.dat, which seems to contain all the password-stuff?
I configured already 12 one-wire-sensors with their id's, some switches and did a lot of configuration, so I would like to keep the setup.
greetings, dna
Re: recover password for login *narf*
#2 Post by TD-er » 12 Dec 2021, 16:42
If you still have the serial port enabled, you can connect to it via a terminal program and give a command to set your password.
password,MySecretPassword
save
dna
#3 Post by dna » 12 Dec 2021, 16:56
Ha. Perfect. :)
Thanks a lot.
jennyluce
#4 Post by jennyluce » 13 Jan 2022, 12:29
TD-er wrote: 12 Dec 2021, 16:42 If you still have the serial port enabled, you can connect to it via a terminal program and give a command to set your password.
save
it didn't worked for me :|
#5 Post by TD-er » 13 Jan 2022, 13:18
jennyluce wrote: 13 Jan 2022, 12:29
save
Please show me what you get as reply from the node.
Users browsing this forum: No registered users and 29 guests
