Hi there,
I installed ESPeasy on a ESP8266 some weeks ago, all fine, great tool
But now, I can't remember the password (so dumb).
Is there any way to recover or reset it?
I have direct access to it, so I can use USB to connect.
Is there a way to access security.dat, which seems to contain all the password-stuff?
I configured already 12 one-wire-sensors with their id's, some switches and did a lot of configuration, so I would like to keep the setup.
greetings, dna
recover password for login *narf*
Re: recover password for login *narf*
If you still have the serial port enabled, you can connect to it via a terminal program and give a command to set your password.
password,MySecretPassword
save
Ha. Perfect.
Thanks a lot.
Thanks a lot.
it didn't worked for meTD-er wrote: ↑12 Dec 2021, 16:42 If you still have the serial port enabled, you can connect to it via a terminal program and give a command to set your password.Code: Select all
password,MySecretPassword save
Please show me what you get as reply from the node.jennyluce wrote: ↑13 Jan 2022, 12:29it didn't worked for meTD-er wrote: ↑12 Dec 2021, 16:42 If you still have the serial port enabled, you can connect to it via a terminal program and give a command to set your password.Code: Select all
