Rules - On Clock - Variables - Logic
obod0002c
#1 Post by obod0002c » 07 Dec 2021, 18:35
sorry, me again.
I'm wondering about this evaluation, is that correct?
On Clock#Time=All,18:24 do
 if [BewaesserungL#AnzahlJeTag] >= 1
  timerSet,1,1
On Clock#Time=All,18:25 do
 if [BewaesserungL#AnzahlJeTag] = 1
  timerSet,1,2
 On Clock#Time=All,18:26 do
  timerset,1,3
Logging:
192027224: EVENT: Clock#Time=Tue,18:24
192027238: Calculate: Unknown token
192031779: WD : Uptime 3201 ConnectFailures 0 FreeMem 21784 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
192060506: EVENT: BewaesserungL# AnzahlJeTag=1
192087223: EVENT: Clock#Time=Tue,18:25
192091779: WD : Uptime 3202 ConnectFailures 0 FreeMem 21784 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
192120507: EVENT: BewaesserungL# AnzahlJeTag=1
192147223: EVENT: Clock#Time=Tue,18:26
192147241: ACT : timerset,1,3
192150243: EVENT
  • why is 'Unknown token' reported for rule#1 (18:24)?
  • why's rule#2 (18:25) skipped?
  • why does only rule#3 (18:26) provide what I was expecting three times?
Thanks for your help
Re: Rules - On Clock - Variables - Logic
#2 Post by Ath » 07 Dec 2021, 19:04
There are a few issues with your setup and your rules:
Setup:
- The event for "192120507: EVENT: BewaesserungL# AnzahlJeTag=1" has a space between the # and AnzahlJeTag, why is that, did you add that space in the device value name? It must be removed.
Once that is fixed, the "if" commands in your rules will start being evaluated.
Rules code:
The third "TimerSet" command is executed because the "if" around the "On Clock#Time=All,18:26 do" is ignored, as that can only be inside an "on <event> do" section, like you did in the other event handlers, and there is no condition within the on..do handler.
obod0002c
#3 Post by obod0002c » 08 Dec 2021, 10:20
working fine, Thx
Users browsing this forum: Google [Bot] and 26 guests
