Espeasy does always send the "Off" command to Domoticz
namxcap
#1 Post by namxcap » 02 Dec 2021, 17:55
Hi all, my wemos D1 mini is connected to a Nextion display. The display can change the idx and the value of the espeasy device (so it works), this is the log .....
but this rule:
on exDisplay#value do
 if [exDisplay#value]="1"
  publish domoticz/in,'{"command": "switchlight", "idx": 17, "switchcmd": "1" }'
 else [exDisplay#value]="0"
  publish domoticz/in,'{"command": "switchlight", "idx": 17, "switchcmd": "0" }'
sends always the "Off" if the value changes from 1 to 0 and from 0 to 1 too, and this is the Domoticz log......
I cannot solve this
:twisted: :twisted: :twisted:
Re: Espeasy does always send the "Off" command to Domoticz
#2 Post by TD-er » 02 Dec 2021, 18:12
You should use %eventvalue1% instead of [exDisplay#value]
And don't use quotes wrapped around the 0 and 1
So something like this will work probably:
  if %eventvalue1% = 0 or %eventvalue1% = 1
    publish domoticz/in,'{"command": "switchlight", "idx": 17, "switchcmd": "%eventvalue1%" }'
namxcap
#3 Post by namxcap » 02 Dec 2021, 18:26
Not working, i get everytime the "Off" signal
:cry:
#4 Post by TD-er » 02 Dec 2021, 18:30
Does the unit itself also act on the switching via the MQTT broker?
If so, then you may want to have a look at the documentation of the Domoticz Helper plugin: https://espeasy.readthedocs.io/en/lates ... #p029-page
namxcap
#5 Post by namxcap » 02 Dec 2021, 18:45
No, it only should sends a command. The device is only connected to the display
Is it possible to send a http command like this ?
http://192.168.0.13:8841/json.htm?type=command&param=switchlight&idx=20&switchcmd=On
with this line i can obtain the light On
namxcap
#6 Post by namxcap » 02 Dec 2021, 21:06
I'm trying different way to solve the problem but it seems rules does not have effects anyway, is like rules are disabled ..... is it possible ?
#7 Post by TD-er » 02 Dec 2021, 21:32
One simple way of debugging rules is to add logentry commands in the rules.
See: https://espeasy.readthedocs.io/en/lates ... l-commands
For example:
  logentry,'exDisplay: %eventvalue1%'
This will add log lines (at loglevel info) showing the event value, starting with the string: "exDisplay:"
You can also call sendToHttp, to call the http URL you mention.
namxcap
#8 Post by namxcap » 03 Dec 2021, 07:32
Thankyou TD-er, i have this log, so now (reflashed espeasy to another device) the rule works. there is only the problem that Domoticz receive everytime the "Off" signal
36867684: EVENT: exDisplay#idx=77
36867778: EVENT: exDisplay#value=1
36867785: ACT : logentry,'exDisplay: 1'
36867789: exDisplay: 1
36867799: ACT : publish domoticz/in,'{'command': 'switchlight', 'idx': 17, 'switchcmd': '1' }'
36868784: EVENT: exDisplay#idx=88
36868878: EVENT: exDisplay#value=0
36868884: ACT : logentry,'exDisplay: 0'
36868889: exDisplay: 0
36868900: ACT : publish domoticz/in,'{'command': 'switchlight', 'idx': 17, 'switchcmd': '0' }'
#9 Post by Ath » 03 Dec 2021, 07:54
Starting with this:
namxcap wrote: 02 Dec 2021, 18:45
I think you need to send On or Off to Domoticz, like below:
  let,1,%eventvalue1%
    publish domoticz/in,'{"command": "switchlight", "idx": 17, "switchcmd": "[var#1#o#c]" }'
That uses transformation 'o' to go from 0 -> OFF or 1-> ON, and justification 'c' to have first upper Off or On, as Domoticz expects it (AFAIK) (and the quotes are required to have valid Json).
Transformations can't be applied to %% variables, so first have to assign it to a variable using 'let'.
#10 Post by TD-er » 03 Dec 2021, 10:17
Just for completeness, see this explanation: https://espeasy.readthedocs.io/en/lates ... red-values
I am not sure if Domoticz checks these parmeters case insensitive.
If it doesn't, then you might want to use the if statement to select different string values "On" and "Off"
#11 Post by Ath » 03 Dec 2021, 11:14
Domoticz seems rather picky on these arguments, that's why it is treating anything not being "On" as an "Off" value :x
I've only been able to get that working properly by using these On (and Off) values, that why I suggest to use these formatting and justification options 'o' and 'c' ;)
Users browsing this forum: No registered users and 31 guests
