BlueDot Sensor (BME280 + TSL2561) - no Lux [Solved]
oisisi
#1 Post by oisisi » 17 Nov 2021, 21:00
I have a breakout board which includes a BME280 and a TSL2561 sensor. An I2C scan shows both sensors and their respective addresses (0x77 and 0x29). The BMEx280 plugin works as expected, the TSL2561 plugin shows no values. How can I trouble shoot this further?
Re: BlueDot Sensor (BME280 + TSL2561) - no Lux
#2 Post by Ath » 17 Nov 2021, 21:12
Have you tried setting the TSL2561 to use the Slow I2C speed (and left that Hardware setting on its default 100 kHz)?
#3 Post by Ath » 17 Nov 2021, 21:14
Ah, the imprint on the board says TSL2591, so you'll have to use that plugin, as they TSL2561 plugin isn't compatible with the TSL2591 (but I can understand your confusion ;)). You'll need a Test_A build to have both plugins available.
oisisi
#4 Post by oisisi » 17 Nov 2021, 21:44
Duh, thanks. I apparently had a dyslexic moment and didn't notice the upside-down '6'. :)
I guess I'll have to mix a custom image once again.
oisisi
#5 Post by oisisi » 17 Nov 2021, 21:53
I'm not alone, it seems in Custom-sample.h the necessary plugin is also mislabeled:
oisisi
#6 Post by oisisi » 17 Nov 2021, 22:10
Ath wrote: 17 Nov 2021, 21:14 You'll need a Test_A build to have both plugins available.
A quick compile and flash later:
Thank you Ath, once again.
#7 Post by Ath » 17 Nov 2021, 22:22
:D We're all only human
#8 Post by TD-er » 17 Nov 2021, 22:28
Ath wrote: 17 Nov 2021, 22:22 :D We're all only human
... /me looks at your avatar...
Sure ;)
#9 Post by Ath » 17 Nov 2021, 22:47
TD-er wrote: 17 Nov 2021, 22:28 ... /me looks at your avatar...
Sure ;)
ROFL :lol:
Users browsing this forum: Google [Bot] and 34 guests
