BlueDot Sensor (BME280 + TSL2561) - no Lux [Solved]
I have a breakout board which includes a BME280 and a TSL2561 sensor. An I2C scan shows both sensors and their respective addresses (0x77 and 0x29). The BMEx280 plugin works as expected, the TSL2561 plugin shows no values. How can I trouble shoot this further?
Re: BlueDot Sensor (BME280 + TSL2561) - no Lux
Have you tried setting the TSL2561 to use the Slow I2C speed (and left that Hardware setting on its default 100 kHz)?
Ah, the imprint on the board says TSL2591, so you'll have to use that plugin, as they TSL2561 plugin isn't compatible with the TSL2591 (but I can understand your confusion ). You'll need a Test_A build to have both plugins available.
Duh, thanks. I apparently had a dyslexic moment and didn't notice the upside-down '6'.
I guess I'll have to mix a custom image once again.
I'm not alone, it seems in Custom-sample.h the necessary plugin is also mislabeled:
