Hello. all
I am struggling with the network connection problem in below.
when I followed the youtube for flashing it on Wifi, there was a problem with network connection.
my laptop's network system doesn't have a problem as I check.
Does someone know why it is happened?
The network connection problem on Easy Esp with ESP8266 12F
- Capture.PNG (37.9 KiB) Viewed 5686 times
Re: The network connection problem on Easy Esp with ESP8266 12F
Hmm that's interesting.
It shows it is not connected, but the web page can be accessed.
How do you access this sysinfo page? Connected to the AP of the ESP?
Have you set the WiFi credentials (e.g. on the /setup page)
I can access this sysinfo page after connecting AP of the ESP and inputting the IP address on website (192.168.4.1).
and I have set WiFi credentials. the main thing is that the notification which means disconnected network also has been appeared at that time.
but, the process can be done.
What kind of access point are you using?
Does this AP have WiFi mesh enabled? (and is it an Asus one or Netgear?)
For Asus, you may want to check here: https://www.asus.com/us/support/FAQ/1042475
Thank you so much for helping me.
finally, I found the solution. it is very simple and silly problem.
because the reason is that wifi password was wrong.
Thanks for clarifying.
Have fun with the nodes.
Users browsing this forum: No registered users and 35 guests
